1963 convert dilemma
I have a 1963 vette convert. I have been restoring for about two years as money allows. It has a 64 engine with a edelbrok performer carb and intake manafold.
I want to take it back to the looks of the63 340 or the 64 350. Problem, ordered the correct air cleaner, wont fit the carb.
Does any one have or know where I can buy the original intake manafold and carb. I have a feeling the ignition shielding I ordered wont fit either.
I am open to alternatives or suggestions.
I am getting alot of money in this old soldier.
Received 1,048 Likes
C2 of Year Finalist (appearance mods) 2019
I'm surprised the air cleaner didn't fit... is it too tall or is the air horn diameter different?
You are looking for a Carter AFB 3461S... expensive, but available
http://tinyurl.com/oqtct2s
the manifold is aluminum casting 3794129, also expensive but available
http://tinyurl.com/m86hyfh
I think something in a chevy carb and manifold from the same era would give you the same general appearance and the a/c would probably fit.
http://tinyurl.com/qazyny7
http://tinyurl.com/kdpm8o6
I purchased the 63 340 it will not fit the top of the carb. It appears the I guess the Horn or top diamiter on the orig. carb must be smaller. THe carb on the car today is a 450 dbl pumper,I am told.
To replace the carb and intake with the original is about 17 to 2 grand.
I just want the look. The problem I see with after market intakes is the
the oil fill tube hole is not there.
i purchased the 63 340 it cost me 350 bucks, the ignition shielding was 700 bucks!!!!!!!!!!!!!!
