Looking for some misc bolts and washers for C2
I'm looking for a few usable bolts & washers for my 66. I know I can find whole sets of these from venders, but I only need a few (or even 1) of each and I like to use originals when I can, so I figured I would see if a forum member might be able to help me out.
All I have left that I am looking for is the little green clips used to hold the wire harness to the crossbar behind the dash.
Any help would be appriciated
2020 C1 of the Year Finalist - Modified
Rustman,
I spent about thirty minutes going through the bolts and fasteners I took off my '64 Coupe during the restomod project. I believe most of these to be correct originals since I have owned the car for forty-four years. Here's what I found for you:
Two (2) WB Bolts 7/8" With Nuts
Four (4) Little Green Clips (As you call them!) Although mine are not green they look similar!
Two (2) Square Tooth Washers/ Mine have nine teeth not seven
Six (6) WB 1C Bolts 3/4" With Split Washers/ I don't know if the 1C head mark helps you out or not.
Your's for the asking if these are what you need.
Wolfman
Wolfman
