F/s large bars of polishing rouge
These are the very large 2.5 lb bars of polishing Rouge for all different materials. These are BRICKS not the little bars....
PRICE TO GO....$25. plus you pay shipping...
Click the image to open in full size.
Here is what I know of the colors and use:
GREEN - IF YOU NEED AN AGGRESSIVE BAR FOR POLISHING ALUMINUM OR STAINLESS STEEL, THIS MENZERNA ROUGE BAR WILL BE A GREAT BAR TO USE. THIS BAR IS MORE AGGRESSIVE THAN A STANDARD BROWN BAR AND ALSO THE MENZERNA YELLOW BAR WE EMPLOY IN THE KITS. THIS PALE GREEN BAR COULD BE USED AS A PRE-STEP TO THE YELLOW BAR IN OUR D C SUPER SHINE KITS. DENIS WITH D C SUPER SHINE TRIED THIS BAR WITH A POLISHER AT 3000 RPMS AND WAS AMAZED AT HOW WELL IT CUT. HE STATED THAT THIS BAR IS IDEAL FOR THOSE CUTTING AT SUCH RPMS. IN KEEPING WITH THE OTHER MENZERNA ROUGE BARS, YOU WILL GET LESS DUST IN THE WORKPLACE WITH THIS BAR. CONSIDERING THE DEGREE OF CUT THIS BAR ALSO PROVIDES A NICE LEVEL OF SHINE. WHEN USING THIS BAR, USE A ZEPHYR ORANGE OR BLUE WHEEL. A FAST CUT WOULD ALSO WORK WELL.
BLUE - BAR WAS FORMULATED TO EXCEL ON ALUMINUM. YOU WILL GET THE CLARITY, DEPTH, BRILLIANCE, AND COLOR PRODUCED BY THIS BAR. IT HAS A #3 CUT TO IT. THE SHINE IS RATED AN 8, WHICH MAKES IT AN IDEAL FINAL FINISH ROUGE BAR. THE BLUE MATCHLESS BAR IS STILL A SUPERB BAR, WELL DESCRIBED AS “EASY CLEAN”. USE THE BLUE BAR WITH A WHITE UNTREATED/TREATED BUFFING WHEEL OR A COTTON MUSLIN WHEEL SUCH AS THE ZEPHYR 60 PLY, 5 ROW SEWN.
WHITE - FINAL FINISH BAR IS A UNIVERSAL COMPOUND FOR COLORING BRASS, PRECIOUS METALS, NF-METALS, AND PLASTICS. THIS BAR CONTAINS HIGH PERFORMANCE POLISHING MINERALS TO CREATE A VERY FINE GLOSS ON YOUR WORKPIECE. THE ADVANTAGES OF USING THIS BAR ARE AS FOLLOWS: ECONOMICAL IN CONSUMPTION, VERY LOW DUST CONTAMINATION AND LOW POLLUTION OF WORKPIECES, AND PRODUCT CONSISTENCY. THESE ADVANTAGES TRANSLATE INTO COST ADVANTAGES, EASY CLEAN-UP, PROCESS RELIABILITY. USE THIS ROUGE WITH A WHITE UNTREATED BUFFING WHEEL, OR A COTTON MUSLIN BUFF.
BROWN - A PRIMARY CUT BAR FOR ALUMINUM. USE THIS BAR WITH ORANGE, YELLOW FAST CUT, OR A YELLOW MILL TREAT BUFFING WHEEL
BLACK - FINISHING BRASS, ALUMINUM, COPPER, TIN PLATE AND OTHER ALLOYS. WILL BRING OUT A MIRROR-LIKE LUSTER ON THE WORK. BEING A MEDIUM GREASY GRADE IT IS IDEAL FOR THE ALL AROUND BUFFING JOB, REQUIRING A BRILLIANT FINISH.
Let me know how much shipping will be to 77566.
I will PM you my address.
How would you like the payment?
Thanks,
Mike
Thanks,
Mike
Rouge
[i will take a set please
Send invoice to me.
Agump@rogers.com
QUOTE=1KULC7;1589271937]These are the very large 2.5 lb bars of polishing Rouge for all different materials. These are BRICKS not the little bars....
BLACK - FINISHING BRASS, ALUMINUM, COPPER, TIN PLATE AND OTHER ALLOYS. WILL BRING OUT A MIRROR-LIKE LUSTER ON THE WORK. BEING A MEDIUM GREASY GRADE IT IS IDEAL FOR THE ALL AROUND BUFFING JOB, REQUIRING A BRILLIANT FINISH.[/QUOTE]
Send invoice to me.
Agump@rogers.com
