F/S 1966 327-350 L79 Engine
Genuine 1966 Corvette 327
High Performance L-79 350 Horsepower
Numbers:
Block Casting: 3858174
Forged Steel Crankshaft: 4577
Date Code: E196 (May 19th 1966)
Front Engine Pad Suffix: F0523HT (Flint Michigan May 23rd 327 Hi Lift Cam Manual Transmission)
This engine was stored in the garage for over 30 years.
Light surface rust in the cylinders.
Rotates Freely.
Removed the rod/main bearing caps for inspection and the crank is in spectacular original uncut condition.
All the bearings look unworn and in beautiful condition.
Its an all original standard bore size engine.
The Original GM 327-350 HP Hyd. Cam is still installed.
Original 10.5 to 1 Forged GM pistons/standard bore.
Original connecting rods.
Includes: Block,Crank,Pistons,Rods and Camshaft.
Excellent Condition.
Boil it out and bore it .020 over and you have a superb original L-79
Shipping is extra and there is a $75.00 Crate fee.
$1,400.00
Numbers:
Rotates Freely.
$1,400.00
Can you post a clear picture of the stamp pad?
Sold
[QUOTE=Mr.Mouse;1589631611]Genuine 1966 Corvette 327
Numbers:
No Longer Available..............
Numbers:
