F/S Points ! Good ones ! Echlin HD Marine aplication
Through a lot of searching I have come up with some heavy duty marine application Echlin ignition tune-up sets.
Marine grade components are designed and manufactured for extended high rpm use under heavy load.
These were made in the USA back when things were actually manufactured (start to finish) in the USA.
These are a premium quality points and condenser set along with the long discontinued pre-emission distributor rotor with the long electrode.
These points have the bakelite rubbing block that absorbs and holds lubricant to maintain point gap and dwell not like the soft plastic rubbing blocks that virtually all manufacturers are currently supplying including DELCO.
Typically Echlin points last 10-15 years as the rubbing blocks and contacts do not deteriorate.
The extended electrode rotor ensures maximum voltage and current transfer for performance applications.
I am selling these kits for the same price as a set of off-shore replacement points would cost you : $25 plus postage (postage to the lower 48 is $6)
FYI : I have 10 of these ignition sets remaining
Received 1,240 Likes
2022 Corvette of the Year Finalist -- Modified
2021 C2 of the Year Winner - Modified
2021 C1 of the Year Winner - Modified
2020 Corvette of the Year (stock)
C2 of Year Winner (stock) 2019
2017 C1 of the Year Finalist
PM sent
Hi Dr.L-88,
Can you please tell me if the point set would be correct for 1965 Vette 327/365 hp?
Thanks, Nelson
Email: briercreekboy@aol.com
Thanks, Nelson
Re : MO's on their way
I am selling these kits for the same price as a set of off-shore replacement points would cost you : $20 plus postage
FYI : I have 17 of these ignition sets available
Thank you guys for the heads up re the money order on it's way
Jerry
I am selling these kits for the same price as an off-shore replacement points and condenser set (no rotor) would cost you : $25 plus postage
FYI : I have 7 of these ignition sets left
Jerry,
Thank you but if you require a money order I will pass. It takes time, gas and is a hassle to mess with filling it out at the post office to mail it in the same trip.
I guess my time, gas and effort to pack and ship doesn't count ?!!
FYI : I have 20 of these ignition sets available
