1966 voltage regulator pigtail
WTB:
I need an original plastic plug that plugs in to the voltage regulator. All GM cars from 1963 to ??? will work. I believe it's called a pigtail. If there is a couple inches of wire attached that's OK, but not necessary. Any one with an old replaced wiring harness may have this.
WTB:
I need an original plastic plug that plugs in to the voltage regulator. All GMss cars from 1963 to ??? will work. I believe it's called a pigtail. If there is a couple inches of wire attached that's OK, but not necessary. Any one with an old replaced wiring harness may have this.
409/409 (02-12-2016)
