64-66 turn signal switch standard column
Original turn signal switch for a standard column from my 66. Fits 64-66. Left turn would work intermediately (have to pull back on turn lever slightly). I fixed it once by bending the little throws within the switch, but it started messing up again. So I changed it out instead of dealing with it anymore, leaving it to someone else who might have better luck fixing it. You will have to source the screw that holds on the switch actuator plate since I used it on my new switch.
$15 plus shipping
$15 plus shipping
