FS 1111024 63-64 original Distributor Cam
Found a nice original distributor cam for the 63-64 250 & 300HP motors. Here is an opportunity to change the cam you have if you are using a different distributor to the factory correct one 24* for correct total advance. Hard to find original part. $45.00 plus $4 shipping to the lower 48 Pilot Dan
ps. I have many other distributor parts like breaker plates, main gears, original vacuum advances ect. PM me if you need something special.
Your Distributor
I could also install this part in your distributor for you and set up to specs. PM me if you want that.
Recently completed 63-64 distributor total restoration and set up
