FS: C2 Rolling Chassis
C2 Rolling Chassis
For sale is a C2 Corvette rolling frame. The frame seems to be off of a 1965 Corvette. Frame has stock big 4 piston disc brakes on all four corners. Frame comes complete and includes rear end, drive shaft, and 4 wheels. Comes with everything in the pictures minus the engine and transmission. Frame has rust and needs blasting or cleaning. Asking $1,800. I don't know much about frame, but I can take as many pictures as needed.
I purchased the rolling frame because it had a 69 Camaro engine and tranny on it I was needing. Seems like the frame was used to drive around in on the property I purchased it from. It has what seem to be a roll cage on it. I can/will remove if needed. Frame is located in San Antonio, Tx.
Will consider trades for 69 camaro parts. Currently needing a dz 302 block and would like to convert Camaro to disk brakes.
Any 4 inch bore block will make a 302. A three inch stroke crank. Boom 302.
I built one for my nova, after I put one in my 69 Z28. It's beefed some. I enjoy it, and it'll turn 7500 no problem. I powershift it at 82 with an M22.
ETA. There are several steel 283 cranks on eBay for sub 200 bucks.
Received 4,583 Likes
C1 of Year Finalist (appearance mods) 2019
That's one heck of a go cart!
