Hood insulation Q (got the new pad today)
Location: San Diego - Deep Within The State of CONFUSION!
I ordered Eckler's OEM replacement style hood insulation - looks good (though it's charcoal colored not yellow like the OEM)
The original was loose 1/2 weave insulation on both sides. It was intact but just very dirty on the original yellow color so I wanted it gone
New stuff as I said, is dark colored but only one side has the loose weave. The other side is like a tighter knit padding and I'm tempted to put THAT side DOWN facing the motor because I think it looks neater. On the other hand, the OEM stuff stayed up there fine all these years and the clips are all still there.
So poll: Loose side down or the neater looking side?
My original is "tight" weave on both sides,and charcoal.Has been there since I bought the Vette in 1979.
Have to vacuum it more frequently,so intend on washing it,and re-installing. Bob Baker quoted $120.00 for the (ahem) GM replacement.Seems they(GM) used different material in 1978 from 1976????
EDIT:Suggest tight side towards engine to prevent loose particles from falling.
I was thinking of doing the same, but because mine is currently lacking any insulation. Hood is aftermarket and doesn't have any means for attaching insulation. Do I just glue on clips?
And it only cost 30 bux or so!
Originally Posted by SanDiegoPaul
It may have been different. This stuff is like attic insulation - you can pick it apart by hand easily. Turns out though that it only goes on one way - the side cuts are assymetrical so if upside down, I'd have to recut it. It went on fine and looks much better than the old yellow stuff ever did.
I've heard/seen alot of folks using that foam stuff for interior insulation/heat barrier. Supposedly works good on inside of doors as well, would be a snug fit though...
$30 from Ecker's? Sign me up!
I think the 'correct' clips - Dr. Rebuild has them, don't remember the cost, but not cheap.
i don't think you can put it in upside down because of the pattern....i thought about that also.
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
Man,that insulation is long !! Mine ends half way. Must be short because it was an Arizona car!!
worst part about is that the side you don't see is nicely finished...i almost think they cut it backwards..
My thoughts EXACTLY!
i never called them on this perhaps a phone call would be in order.
When I had my 79, I put new hood insulation on it. It looked exactly like yours. I always thought it was upside down too. That has been at least 7 or 8 years ago.
i bought my under hood insulation(the first time) 3 yrs ago from bolingbrook chevy in bolingbrook illinois,it was still available for a 73 coupe and was ard 50.00-over the winter i wanted a ''freshen up'' under the hood so i bought one from ecklers that doesnt look anything like the g.m one i had.the eleckers insulation looks like someone made it out of a roll of flat insulation material in there garage!!,,,nowhere the same quality as the g.m------i'll just get the g.m again when this one starts to look beat up-now i check with the general before i buy parts to see if the origional are available,some of this aftermarket stuff is garbege
I have looked every where trying to find something like the GM version.No dice.I'm going to wash it by hosing the turkey on the drive way,then let it air dry.
I simply painted the yellow side black with spray paint.
I shook it out a lot to make sure no bits would fall into the engine compartment, then installed it.
It looks great. I have a pic, but its on a different computer at home.
I'll post it tonight.
