HP Rating for a L48 - 1975
Question: I was looking in my repair manual and it stated there was (2) Horsepower rating for the L48 350 in 1975, nothing special but 195 and 250HP; this may be a stupid question but what is the engine difference in these ratings? I assume I can find what I have by looking on the right head? I did a search but found nothing. Any thoughts? Thanks!
look at the VIN and decode it from there. if your #'s match, you have the lower Hp model. if memory serves right, the only major difference is in valve springs and cam.
Originally Posted by big_G
There are many differences...Crank, pistons, cam, 4 bolt mains, valve size, screw- in studs and guide-plates, carb, etc....
l48's came with the lower HP..i'm not fully awake yet... forgot about the 4bolt block difference
Actually here is the 75's numbers
Two engine variations were offered.
L48 - 165hp
L82 -205hp
This site has a great breakdown for you.
http://www.idavette.net/facts/75.htm
L48 - 165hp
L82 -205hp
L48 - 165hp
L82 -205hp
L48 - 165hp
L82 -205hp
Damn, 165HP! Crazy that is a 350! My GTP has 260 and it's a V6; I may have to start modding this car! I hope the Dual exhaust and Turbo mufflers will help. What else would help and would not affect the originality of the car?
Originally Posted by kdf1986
What was the Corvette year with the lowest HP rating? Was it 1975 when they first went to the single catalytic converter back to a dual exhaust?
kdf
kdf
1 Post
Recurve and set timing as per Lars paper, add true duals and you'll jump way up in hp. Before I changed engines, I did only what I've mentioned to my stock (and tired) L-48 and ended up just over 200 rwhp on stock manifolds.
St. Jude Donor '05-'07
Stroke it, new cam, heads, intake, carb, headers, exhaust....should make it a little more fun...
