Normal water temp and oil pressure reading?
Hi everyone.
What would you C3 drivers consider to be the “right” oil pressure reading when the engine has warmed up? My 1976 L-82 vette shows a pressure just below 40 and the water temp is normally around 150.
The “warm” air inside the car from the heater fan is not warm at all - is it possible that the thermostat is too cold or even stuck partially open?
Regards, Icyvette
Regards, Icyvette
GM considers 40psi at 2000 rpm ok..that is what I have at 123,000 miles on engine..(78)
If your thermostat was restricted,your temps would be high...try a 180.....also,sounds like your heater control valve might not be functioning right....not getting enough flow through the heater core...
