68 door lock cylinders .
Hi
When I bought my 68 about 5 years ago, there where no door lock keys ith it. When I tryed to remove the lock cylinders, they disintegrated to dust, completely unusebale. I found a reasonable one used, so took it apart , removed the 5 key plates , went to a lock smith just to find out that 68 keys are again unique. No way . I got fed up , also because this lock already started to produce this white powder inside ( cast corrosion ).
So I went ahead and ordered GM 74-90 locks with keys P/N DL-5.
After removing the stainless cover, the blank cylinder comes out and fits perfectly into the 68 outer shell lock and stainless push cover.
Of course, the end bit required modification, but this was rather easy.
I now have 2 brand new locks in the original 68 push button setup, completely unvisible from the outside and still have my original 68 cylinders which I possibly can get overhauled at a later date.
This is a chep mod taking some hours of fabing, but well worth the effort.
The next 2 pics show from left to right :
#1 , the outside shell of the 74 lock. ( removed and now scrap )
# 2, the complete 74 door lock cylinder
# 3, the 74 cylinder with the 68 end installed ( it is 90 degrees turned to the original end ( that is now cut off ) of the 74 cylinder.
# 4, the 68 blank cylinder , above the 68 lock housing and top the 68 stainless push button housing.
# 5, the old 68 cylinder assy, completely corroded inside , the end bit removed and installed to the 74 cylinder. ( it is only pressed into the 68 cylinder. )
This pics shows again from left to right
# 1, 74 cylinder inside the 68 lock housing and push button stainless housing with the 68 end installed .
# 2, 74 complete lock cylinder, new
# 3, 68 blank cylinder
# 4, the old U/S 68 lock cylinder assy, end removed .
This should make it again an 35 years +.
This summer, I can lock my doors and bad boys now have to cut my top open to get in.
Günther
Günther
carriljc (02-28-2017)
Great job! If your interested, a pair just popped up on ebay.
http://cgi.ebay.com/ebaymotors/Corve...QQcmdZViewItem
Bryan
Bryan
There is a guy selling 68 locks on ebay from time to time. I ordered a set from him last year. I think it was about $150 for both doors and the ignition, keyed alike.
Regardless, Good work Gunther! Two sayings from my parts work well here: "Necessity is the mother of invention" "There's more than one way to skin a cat"
Hi
Yes, I contacted Paragon for the rebuild service. About 25 USD each, but I am sure, the bare cylinder must be corrosion free. Myne on the car are not. All is diintegrating into white powder.
The once on E-bay are again without keys. May be rebuildable , may be not ? They will be at least 100 USD + taking the chance.
My locks are now like new, the cylinders definately are and I am happy as is.
From the outside and even, looking inside the door , you will not be able to see any difference. You must take the cylinder out of the housing to spot it.
Anyway, I promise I will tell a potential buyer, if I ever decide to sell my 68. Right now, I intend to keep it as long as there is fuel available.
Günther
Günther
Gunther sent me his pics
And he said I could put them back in the thread. here they are:
I will be trying this so I asked him for the pictures. See pics below:
Thanks Gunther...
Thanks Gunther...
Hi
Günther
Günther
Nam Labrat
Received 4,173 Likes
Housing springs...see other thread you posted in......Hemmings Catalog 1965 Chevy Truck buttons are identical (per locksmith).
doorgunner
Are you saying that 1965 Chevy Truck doorlock pushbuttons are the same as 68 corvette doorlock pushbuttons?
Nam Labrat
That's what the locksmith told me....mid '60s chevy trucks have the same assembly. I checked on the internet...some models had identical pudhbuttons/some models had identical assemblies including pushbuttons.
https://www.bing.com/images/search?q...tons&FORM=AWIR
[img]data:image/jpeg;base64,/9j/4AAQSkZJRgABAQAAAQABAAD/2wBDAAsJCQcJCQcJCQkJCwkJCQkJCQsJCwsMCwsL DA0QDBEODQ4MEhkSJRodJR0ZHxwpKRYlNzU2Gioy Pi0pMBk7IRP/2wBDAQcICAsJCxULCxUsHRkdLCwsLCwsLCwsLCws LCwsLCwsLCwsLCwsLCwsLCwsLCwsLCwsLCwsLCws LCwsLCwsLCz/wAARCADIAQoDASIAAhEBAxEB/8QAGwAAAQUBAQAAAAAAAAAAAAAAAgEDBAUGAAf/xABAEAABAwMDAgQEAwcDAgUFAAABAgMRAAQhBRIx QVETYXGBBhQikTKhsSNCYsHR4fBDUnIWMwcVNJLx NVNjgqL/xAAZAQADAQEBAAAAAAAAAAAAAAAAAQIDBAX/xAAjEQACAgICAgMBAQEAAAAAAAAAAQIRAyESMUFR EyJhMgRx/9oADAMBAAIRAxEAPwC5IM80u096Mp5rorxpHSDnp NOpnzmhApzMe1QMQzjtQZ7n70R6RQnimMFRI69RQ QTnJozGf1oTn0oADMnnvQndGPeaM4qBe6nY2Skoe WoqMKUG07ihJ6qoAlGe+O1IeuagN6xp7riBv2ocM NuKP0n1jiuc1O2IIZ+pzMhQICekmgdE2T3pCSQRN VNtqSvmFtXC0lK9qkKAjZOIMdKtTFAdAkq4HTmZn 2pJIEk0vY0hgDNMAeDgmkknGaXrmmnnPDacUOQIT/yOBUt0rGOt7Ft7wv8AeKT7VHvXxa27ju0qIBjsDH WqG8X4gCSpX08FJIPtUS11hNq45buJW/bLwtLipWDGSgmvOeH/AETXNStd1+f9N04J00TDfW9wyVXLjaHkoDQCwfDc RMiNvWntM+dQ9cLUj9ivYlCvEQtODjbtquct9Nvh u06+YCuTb3B8NST5TTTVlqLDzW9aW296VENOEhcZ iBirXFJpPi/TKav9NcZz096QnnNRk3UrIiUJaAKhyp3mBPamXL1 QbSoIAUuDHYz1ro+eN1RjwZNWtLaStRCUjEnAz3N R7e7buIAU3vlX0JWFKgGJgVV39w+424toqcbhJ2N/UtsjB3pGaZ+HAhRvX1JWHiUoBWgp+jkgE/nWsJOa5PRLjRoaHrPrFGQehzNJg/pWhIEHPOYpCDSyDIkSOR51x5HH2oAbIptQ4zTxH3 oCP8HFIRHUD3oNtPqH6TQ7R51QtmxjmfShiKcPM0 MEmkwQqU8T50sdBxS8CkNSMEx/WgPGfaiPSmnnW2ULdcO1CASokdPKkMU9MUEjEdia pnNfyhxFsRbhYSsrP1kHtGKsba5U+AothKViWyFB W4DJpOSTpj4vseMSP5ViPiOzubu+U5ZkkJSlDwUu EynBVJrVP6pY27rTS1n61bCsD9mlXYmqrWdNf1BR XpziS4FJ8ZAWAhQAxu6U3lWKpMag5GbbSi3RsW8l wNNqcWUn6Cs/upNPWziWEo+ZcG/Zv2mdwSoyAQM0xf2C9Nh68KHdiApLTCgW0ukwlLi vKqi2ceubpbziicEqPQTgAV0Yo818l3ZMnX1L+7f aDrTjCpSpJnpmZzV3pOqBwJtnjmIaUTz/AAk/pWXUlUJVB2kEJPeOtchSkkZyCCIpzxJu12NPwehH 7+tDHFVGk6sm5KbV9UXABLZP+okfzq4zGfUY6TWD TXYhI54qt1N0JDbQP/5F/omrImCJxPnxWYvbnxXHHOAsnaOyRgVDXL6lIhqcl RPn+VQLi0cKlOtgTCsHsakyCSJ85qOvUG23HG4Kg MSOhHWulKSX1Fa8lR4Vwwsr2ic5wYq8067DqCkwl xHMdR5Ux83arnemQe4FRrYKRdF1sQwVT7dhVZI/JH7LYRfF6Zp2n5Cknokn7VUrvFNOOtuSW1bnAoHK R5Ck8d0KkK78xwagXDClKUrxJUcies9K58OGKezS Un4FWm88Q3LDxWVGQtlUKHlAq60a51J25QbtSlBT a0IC4CgeZgenWsv4Vy0dyPEAnlJMT7Vtfh9xDtkl amouUEtOrI+pY5SqTW+WCpPRjF+y3INIPznNERme p8+lIT/nesRgke0c8ZoaKSckAdM5pIjsYJM8UAJ3oSM/rR56/frSRJ5x2/vQIbKcYim48h96eI/w0kJpDNYrk4pUikiSTR8U2IE0JnM8UpFCfWpAE4q g1y9Nu4lpSm0JUz4jZckp37usVf8AEenSqbX9OOo 2yG0IHiBUhyJWgHqny70n+lLsyNxfPXgRasBKy6+ FkoTtU47wP/1FWiLhTajYi4bLli2GXAlQkrX9SjA+1TLb4at2WH m7dx1Fw42WzdPRvCj/APbSMAVgHG7vT79balkPMvKQpaTIUQeZ86rDFZZc vXVlTlxVI09+kpZRO6S4BKsEn0qxCii3bV12gDzr NqeechbqipUg5+9XjVym4ZRtSdzRhSSccVeRWC6K/VmlvWS20planG1AdOck1BtbW1tGwq4XCZ3HoVkdE jmr15h9xlS21htafqQTnI6EGsncfMrdWHlErSopP UY7RWuJ2uJMluyZcagh91AQjYyiUpGODSEjBBwYq u2Lg4P2NPNOqT9KpIx7VtS8GdtEuVJU24hRS60oL bUOQoZmt5Zvm6tLW4MAusoUoDgKjP51gcESOCK2G gOlemNpPLS3Wx6btw/WsMi0WT7gKLNxEAltYBPSRE1jn3Ix6itsQCNpiDg zWAut6Hrhpf423VoI9CRWeNWwboFb4bacXEmIEnr 0iqclSiSZJJk+pqa4h58paaSVQZMcD3qWzpqExvV Kuw4FdVqBNORVpbdV+6Yqe0lYSlIGAPWrBFoxIAS THftTgZAwlWD3GKzlPkVGNFepKkfi471GuXFQiJw cYqyuGlpGYVOaglKDKT+Ej7GiL8lS9DCLpxAghJH UVffDr7r13cpSCGwwFOdt26E/zrOPILalJPA4M9K0/wALv23y77ASEvKWXSo8uAfTHtVTS43RmrujRHz4x SH+vrRY96TnkfauUoCMH/DXHHfNGT7UNIAesVx/+KWB/KkIpgCcfyru2a4jjvkiuigRrR18zXGB60sROKGIm JyczTYCHr6UB6d8URJ7TnNCZ7CpoAMxk+VJRGgx9 5oATqDPUV5XdoK7+7dWMeO+pA6ZWc16n515xrIU1 ePsqYLakqUdxM+IkmQR5Vri7BkUIMSTM8D0q4skb GlK6rMx5DE1nC6QRBPStbY26xbNFcbtu9yec5iqy IuLHB9SQk8RxP6027a2qseEnAkmO/nT4KZWYHGAKbdX9MAx2jtQoq7JciE5Y28fs5GJiZ 9qgPWUbvpCo6EQatUqKkyk9/yphwmCe/UGn/PRSdlIUhB2iR5HpWm+GFgsXrZ5Q8FD0Ukf0qguRJ KsT+Zp/Sbt63XcJaVt3pTuwDMGql9okeTaKMBRJAiYNYrXE lF+XTxcISsq4G4fSatl6hcrQ4FLORjaE1mLi8Nyd ji1qW2VRv6d6yxRdg+iawQlMAR/PzqQCVAetQrZQUlPeIFG/etW42JAW72nCf8AlWjjsadInpUlO4EwCMk4j3pl6 5tUhMvI5GAoE48k5qnPzt6sAlRHRKZCR7CpzOjOq ALio8h/ak1GC+zDb6DVfWe2NxVBIjaqY75plTlk6PoUEr/iBFSlaOwkElaveaiP6Y4gS2SrBMdaiM4NjaZAviU lhUSidqiDzGRTrF14C23GyUlMFJGI8jFNLJLa2lj B47pUKY4xniuqk1Rlu7Nta6v8w2FJAUoABQ6zUtF +lRAUiAeoPHtWS0cr8Z5IP0+GCfWRH86vOg9K5Zx 4ui1tF4khQ3AiMUsGarWbotp2kE9jPFSEXSVwkKy ZMHj71mxkk8fzpDkmKDxDzg0QVu/KhAJxGRSQrv8AkKI+xrqANYZBVj17UJP6jmnFHkm m+JmrZKBV+ZoDPejH6ZoJzUDBI/OTQmO3Si6eeaA/nQAh+2aznxIyi5Fs0EgqSFuFQEqEmAJrQrVCSe2c 1i9V1plD7oQgrdSSg7iQgAd+tOKbehmcQyU39vbL wovtJMclKiM1t3127TWFbUpH1FUACBmaxqHHLvU7 G4VtDguGPwCBtBp/Vr5dw+plBJaQrYAnO9cxJFdMo3SJTJdzrjLcpt2i s8b1kgeyRmq83utXUpQpwJmf2aQkD3A/nVnaaRa27IudQUlKikK2FWEjnPnTFzrmnMK2NAuB J4aACMcZNNJL+UJsgm21WPqW4BzG5VMk6gzP1uQI 5Mj86fX8QJXui2Anqokn8q4avaOpIc+lYEp+g5PY mm1NeCouLI4unDhwA+Y5+1SbBQL+DhSVffmojhZf lTYhfOOvkaOxUU3DQ7kpPqabpxG4tMvCMVmrtPg3 a+ylbvY1puhqj1hqC04MY2n9RWWJ7JmtDXjqYa2p/EqQk9h3pLS3XcOpAOJlajmoylbgk/wgD2qUbo2lqkNmHHRyOQDXRVKkRZcO3+l6YgtoRv dPITlRPmaq3db1W4JDCQ2n+EEqHvTel6b8+vxHlK CN/wBRH4j3AmtW9pluw2kMNDbH7ok+5qXGMe9sacpGM Xc6soyt92c8k0Tepagxt8RZUkkfizVrc25lX04Bq uctkrC09cx2ppxlpoHFrpivOIePipEbxKwOiutRA oKJGYHXv6U/Y21xcb20ADb+JSuE/wB6s29IbCgp51TndKBtH3pNxhoFbJGmMBm3C5Bcf haiOg6Jqw696BDaW0hCMJASEjoPSnI949a5G7dmi VCf2pRM4weYp1DDiyO3epKLdCeRPmamxjTa7glPJ FS0ng4pI2wABEUkn/O1Ah4kRMUO5NBuMc8UkHypAbQxmmznzHY0auVU2Z P3mrkSgVeX27UJ9OADRGaEz7eVSMAz09aEwMn8qM 4ihI/OkMbUkKlJ6gj715TfMPW13csvA+Ih1YUT1ySFD1r 1cg1Sa5pNrqKAo/RdJTCHQMED91Y7VcJcWKSs87Q6W1oWDlJBHSp2lp aVfsreUA20lx9ajmAgTNcpvU9FfUpbLcKBR+0bS6 2sfwk1C8ZSlPwPDU6lzCRtBCslIHaup/ZaJj3sLVdQc1C6UhhS1NYSgRAPomry0+EkotkXN2 8SpaNwbQDgkdTVZoFn4r92+tJIt2/ETj96a9BICtLYcle4oVIHfzpyfH6xFVu2YZ/TbRsKQlGR1qnuLLYCpPFaV9xQ3DG4k4IyBVTcKH1 pI6Ez61EMkrLlFUVNu6tpeyfpV36VNtdy7u3A/wB+4nyGaiKbAhyRjcKkWCibpmOigK2n1aIg60zSj rHrVfqjJXbLV/shQ9qsh5e9NPI8RCknhSSD61xxdSNHtUZNAUoKgE hPPkKR0FxCSOUJEjyFWen2lx8w7+zVtRIVKTBH2i pF9YMJadeaSULAkpT+Ejriuv5EnRjx0OaQsICAOC En8ordqbC9OadAASUlKoEZFeb2ThCWCCQAdp9Qa2 Vn8UX9paKt7GytlLbPifM3YLpRAgltqQn3NJ/pS6K560uX0XKmLd5wMp3PKaacWltPdakiB71S7Sl WQQD7VLXretKN20b252Xit1y0hZbbcJ/3NtwIpj5lskNLG87SYjAA86zqui7RIsUFs3AA/ZqUFg+ZGamnEYkntUW1ASoAA7XEyJ6RmpnYVjJ7G hYIIMe/epVuhszOSPeoo9eOf7U8wqHE+eKzAnwBgeUV2Of0 8q7gcH2pOn51ICZie/SkjpR9vzotiSMdqYDJj6ZHWQaL7UpTHNDH+RRQGz MyZwBigVTisz69abMZrSRKAJGIE946TQmiOP7UlQ MGKbIGfSnTEGgpDBxGKbKQYJHPenOv+RQGKQEC+s UXSQJSCOJE81kNV+Hb5bjam1t7UgiciM+Qrdny96 Epxn881UZOLE1ZmvhnSbhld9bvLQpVww4AWwowUt qMkGp9hrnw5baai1vfnn7iVb27FKCE/Tj9o4QkedN6t4zLK/BKkfMK8NSmyUq2EEqGM5qpsdMtr/YhV18syVbVFABUgTkgd62jK9sffY2t/TVNrV8jc+MpRUharobUp/4pTzVU+0lydspUZ+k5x61M1TTLnSrhbdrd/OWiFfQpSEtuqR/EmSKh3V21cFPy9qbdCQlIClFS1qHUk96pR8oOXgr FsOkeGEqKw5gAEyCPKtBY2qGGWiW0pd2DeYzPOaV NsWH2JWlRcbKoHI6VMGBSnNvRKjWwYyfOu2yOB16 0fpRIRuUhPc1iWOWScqSeqc9qS508eE6d0gg4jvU 9m2Q0JJkmPanHU7kqSeoPGKLEYxiydtVObtqkbgU EzgnHFPKQ6tavrPSAnEg9RU95IBUg9yPzpvYhYSh ScAj8OFH0Na82xVRVvpU0NjTat6o3OYhIPOTUb9m iW2ZW4vlRyYqTei3K1BlNwlIJlDiwrM96gJcWlYC U7YI81Hymt4rVktmgtEubULd6J2oHUDualCTmgaO 5CFEEFSQYPSRTojEzHSuRu2Wjhn6RyD0zU9ppCUg x9RHJqLbkJcyAQcVOAKQBJUM5VzEzUDFMGMnkYro BkE9waTriix7UCEGBzjzFOJ4FBBPQ0QkAmCY4A5P 3oQCkbjFdtHn+dKokCUicj7UQmBiqA1KsE+tAZ6d 804RQmqkSN9T5c0JMTRnr70JFQMA8TQETRx2/PzpD6UmMCO9ARgwY7eVOH1zQR0qQA6Hr3oSKMgHn pxSUARbltDqFJUOm4GJgjrWeGmJDqocW2hRneg4H scVqFpweMiKgFh0k/TiqVjujPX1gGpJvFrbHJDQmPXdFUbrzFsrckLWoT tUuCfaMCtfe2r6mXkKKRuEp+9Ua9JCkr3ucj90Z/Ot4SS7ZLd9FXZ3Tr96hajyCkJHAHvV+O9Qrawtrd W5IJUP3lRIqbnBHrUzab0NfpwyD0zjvVrbsshtCg JMcmqsTJq1tSVNJA4Eis2MfgUh86WTB9qTJATHWp EVz9mpxalpIg9+aBOnq3AlXUcCrQInmjSlI5p2BQ v6XbhxS1blboPOKaNnbtqCktJBjmJP3rQuMNuASo CKhv2i1DaiDHtNVb9gVgEEdM+tLMkZxNP8Ayz+fp xQ/KvxgpBkcnp14pDGgSDjmQas0nckKHBA55mo6bUAg qVPp/WpIASAAOKTYjvOiSJ5xSDp6VwGc/nQA6BBmK7nBpZEUkyDGcfnTA7pyKUTA5+9CMROBR Qe9MDWKHNNEDntTyuTimiKuRKAg0kGnCKA1mMBQk igJ/SnDPJoSBBzSGNkUJz2GKMjz9zQQP1pACYmkPrSmM 96AmJnAgqJn35pIDlcxGMRVfdatYWrgZ/aP3KsJt7RJcdPTO3imLq8U+HAl0sWbag29cAStxR/02QeVVAv9auXUsaP8OWC7TJWr5WXdQuCOVP3AE9y YPviK3x4uW2Juhq+1XV3AWzb2VkgxHzbu9+P+Cf6 VWeLqTjgSNa0pBM/91txCOCcq2GmHtK1hiFXqSwVEkpeMOe4Oc1DdZWT hYIAj1rpUIrVC8WWaR8RNt+KbVq7t0mVu2KkvbB3 Ulv6h/wC2nWr63dUG9wS50BOD6GqJm6v9PebuLZ91h9pQU lxlRSoR+R9xWuDmk/GdupBaYs/iltsuMPMJDVtqxQJLa0jAd6jv7wklhT2hKVaERb3 CjGwiRMniKsmGvDbCCeMmqHRNWdK1adfEh5slDal yFSnBQuetaMdRg4x3rjnFxdMtOwTOcUCnENAuOrS hCclSzA+5pu5uWbVpb7ywltAnzJ7AVRAO6kEajqC 1s6WFkWdo0YuLzaYJSDwO5pwg5A2XDd9e36ltaNp t1qC0D61NoIaT6q/qRUO6/wCsGZ+bd0jTzE+G9csF5I7KSCozW1+GtM1e8sHUu vHSdHKlFiy00pbdUCPqW9cEFeeuaZvGv/C7SvEQRav3SAYC1OPlS+DuWkETXZDDFbZm5ejBC8 11KpGr6c9iSEFsiT0ykU4Nc1W3/wDV2jbqD/qW5jHfEitA7efCNz9KW9KaSQYhKkq9PqFVLun21w sq05wpIwA2oFJx24pOEX4BSfkl2upWN6EBC9rnJb cwr0HSpK07ehIJiAOKoFaW8tQaUj5e+3wwsSlm4P Oz+FXapmnai6FmzvgUvIJbBWIVuTgoWD1rmnj4mi afRZFsxgUhSqMDkYp3kevFdBnnEcdqyAYg9RxShJ 5inT0iDHPlXRQgEHAooA4OIHNIaTJ96YHGSJ5rp8 xSV0poA2KsEg00QT9808qJNAa1kSN54oSD604R1o TWYxo8Se9CQOacImYzQkVIxpQoDB44p1U/agOJ79KQDaoqo1W7S22WgraNpW6r/akc1cpSpa0oAypSUj3MVR/GdmLEttNuBXzASlwjABSnepP6VpBW9if4ZJeou3L qGhKW0SlhHRCSck+Z6mrux1Y6C2t+yLfzz6FNFSk hS0IMGQTgeVUFpaq3LcdIBSCpOQAQMkVa6TYNXTz ly4kq+vdK52+QSOK6ZSUehL9G/ktY1da7h9ax4qipTjxJUZ6gHNTEfC7aE4uHQowfr gj1j+9aRDYSkfeKL/5rneRjox9zoFxbocWp1L7U5GzapI9QeKrF2K7JVp c26nUKVcBQUCNrSkwpJEZma9BIBnGDIrP6palLb7 SSEtKUhwSODMCK1xZW3TE0hj4ksmhf2mqI2oRq+n Mamnw+E3EBDoHnIn3qZpl4HmkeIchvM8Y61F19dq wzoFqy+483bWa0BTiYIW4oLWlI7AzFQrHxFI2tk7 lqUkR2NGRWxroZ1R03944p3cmwtEghBx4gnH/uqfp7ibpz5y+KUtsIQGkgQlCECAhAHSqzU0PM2tu lwkuXVy8pfeGjsSB5V29abW3ZB/GoqUkdkxANbVxRC2aTVPim8uLZuxtCUNKSkJaSYT icPRk9D2rPt6XfvErW6gqWZVCIAPl0/Kp+nWDSSVbcnK1HJJPcmrxLaUpwkQIgedc0sjbLS SMuvQr05S8kmDhScfcU3aJ1nSbpt4tjYhQVuTlpY n8Kx51riDAxTa20rSpKkggiCDRHJJA1ZrNNa0P4n 0xxSGw2swlxB/7jDozg+XSsj8VaShNjb36UlOpWVwmw1NaZAuBBLF z6kCCf6VO+Env/ACvUdRYIUpFw0hxogxsLasyOsgx7VoPie4tHdG1d rwkl52zdWVwJBYWl1H6muxVkgYp8JUYPT7tVwylK z+1QAF+cdRVgndAkiYyRwazGnOw4qDMpSqtG2oLC f4hNefJVo3DmcDmkMgyO/wCVFHHfj1rh060gBVMYyY4Fd0zg4pep8uKSgQmDQ +Ej/JozEdJNJnsKdDNmrr60O0mi6nPOKUjp2q5Eob20J SZx0pwRPp9q4486gYwRnigUKkwIP602oUhkYheMC J+ryFCqfan1D8zTShGO9ICO44ptKnBygSPaqD4mc U9oul3ABUtm9uUvq5J8VIIk+1aB5MoWn/cNv3qqs0298m40K7UEfPS00pU/Q+nKFf5/OtIAYdK/GtxO4AObFdPpInpWx0hpCLVoJ4PfNZC+sdQ0e9ur C9aLbzRGCTsWno4g9Qeh/wAGi0C+Zca8FSwlaDgKPIPatJrVoSdmhzmkMUpgT 58V0dPeucYkdJHPSol7pOq3IZ2NEtPINypXRFu0f xL9TxQ3V+yyChK0lckEz9KferF3WU2+iutLU6t67 QEKeUYLoAhLLA6IHU+vetccfJL9HnWqOl+6bZQSQ wAgfxGc1ffDotWdX09N03vZQ6sLQeCUoPSs88hYc LgEuuL+kDoT29KtGfGtlWrrcqcZWFKJ5M/iJracloEjRfGdvYXllompWFoGrdF1e2rm0D8W7en dHeFVi2VIXcNgGQlRwfOtjZ6ky+zr+gXKkto1AG8 09a/9O6G1YSPIwI/vWEe8S3uXElKm3W1/UlWCFDmiTb37GtKjbWaQGkcZyaljz5FVOlXrVwyk JI8ROFoPIq2JHPHSuZquxiScTFLHOKT9M0Dz7DCN 7itoAnPJ8gKSActCGLl15W0J8Hwws87iZgVG1rVQ u21OFyPllNAg4+shNU7uoblqdJIE4APGOtQdRdcN ulkIO9xSXXx5DKR/Ou2DUY0ZONysjaSFlbhJMBOPvWntv+36GqOwZLSC YgriB1iry2H7MeZNc2R2zRKkSpxXRznmljCZj/O9dAg4rMYnn0pJ+9L0AGMUp9KBAGIg0oIgc1x9KU RAx0700BsuCY70UfyoZEnvRjMdKuQIQJEn1xXFBM +VGMzHT7CjznzrOhkcIMGfWgKSYggjyqVtAzA7DH NNqT5QPLFFARSMnGBTSgZOKkrTkiKZUIzFFAR1J5 rM6/YvfTeW24KQdy/DJCgRwtMVqDnM8UytIUCDBB5FOLcXaE1Zk/8AqDTdatm7D4pZdU8ykostVtQn5lqf3XgcEd/0nNQbj4eu7cId06+tL9lUKbWw54bqZ6LQo8+9T9Z 0JUruLRMzKnG0jnzArKlWxW0qW2pJP0yUkH0Ndak p78k1RftvfErASkpeTAOHNjgPvNPpd1N8EXLyUDb MuOhtA9azXjOnHzLu3tuP9aEuWqcuLUqOilYp8Ij NrZPfCVgwt+6UrWNUgqYt0JUmyZWONx4PfrVRf3j 7rjl9qLoBVPhstjalIPCGkeVVLV+pI2WVuVucb1C EJNSGbJ5xwXF4suu8hM/Qkz0FROWqQJeQrZt15z5p1O1J+lhs/uIP73qavbZiQXFAQQQB5U3bWpUQpQhAiB1NWqEYA 4A7VzMozetWzwZS62Sl1iCggAFTYOIV3FVirtjVU JNwQ1qLaQguKwh8AQN/8VbS5Yafb2LAyCBIrGanpTlsSUo+iSdwmK2wypcW S+7GUJftlBQUUOBWCOPuKs2tbvkghRYc/wCcpP8A/JqjQ/esATKkYhKxuBpxF/bKWfGsWzMYbUpGa0eOxqReL127gJSLcEpklIUY9J MU3bjUtVdWm2t7q+fA+tNu2pzb/wAiPpH3qG3qmmMn/wCjtvGZT4r6ykewFaa1+KNdbslW1s3aaXbqR9As2 EhwzyrcqTPnR8aXbKSk3SRBVpq7FaU3+wXuCi1So FLPm6R18qc1e30i3fYFhdLui6yhx0uIgtun8SeBx VYblAUUNFTz6lFSlqVuJUeVKWadYaUCVLUVOq57A dhWUqL4qHfY82gnakDMwKtG0wlKce1MMM7frUM9q mIT1PtWTM7CjgD/AA1xmRjrmlg5pcdzJpUAkjjGBSHpzEc10nP+YpJV niMU6EIeQKSuPnSe9MDYJUSZ96eQonoSZ7Yiurqu QIfCT1/TFOpE/u4BAkiurqmhhFISDMyTiRTK59xggV1dSAirUEkAj KjjGTTLnBma6upgMkdwQKZXx5zXV1CAbUO46VVX+ jafejc6ykLPCgIPvXV1IRRO/CrKT9AKhn94im0fDraCP2CSR/uO4fnXV1Pkwomt6WtIAhKEjokVMbsW2ykwVHz4rq 6ixkrwyAOkEdKMHmBXV1SwOORkU242h1JStIKSII UMV1dTAorv4faXKrZxTSj+6fqQfY1TPaJqTROG1C eQIrq6tIya6JYjdlqaOEspg/iIJI9KkjT7l0g3Fw4sY+lI2p94rq6hzZVv2WLFgE YQgJH61NatkpIxJ7xXV1SIlJRFFHHkeBiurqKQHe xmujymurqQAkeWDSQZ9O9dXUAAVV0HtXV1FAf/2Q==[/img]
Nam Labrat
The following 3 users liked this post by doorgunner:
So....... that's a 65 chevy truck and you can just swap the "innards"?
My driver side is broken and I've been putting it off for years.... really the door locking lever (I believe it's called a "door lock pawl")broke off....
I wrote to Classic Industries and asked if they had some 65 chevy truck door lock assemblies...since I did not see them in their catalog. If they answer me, and they do, then I'll go eyeball them.
