Starter interrupt relay location
Hi everyone!
Like someone might have noticed, on this forum (jumpstart a C3) I have some difficulties starting my C3.
Like i mentioned in my previous posts, I found the battery and the starter are ok.
Now I only have to locate the neutral safety switch (A/T) and the starter interrupt relay. (refer to Haynes Manual page 12-14)
Some ideas where to look?
I would also like to get some idea of how to remove the ignition key switch for fault check or even change....
Icyvette
Icyvette
A/T neutral switch fault
After some hours of wiring speculations, my friend dropped by with his good car-electrical knowledge, found the A/T neutral switch to be fault.
Jumped the poles on the switch and everything is back to normal.
