I need some info on removing rear deck lid hinges. How do you get in to remove the top two retaining screws? Any info would be a big help. Thanks Dave
I recently put mine back in on the 68. The most difficult ones for me were the inside ones nearest to the body. I used a 1/4 inch ratchet with a medium length extension and a universal attached to the socket. The only way that I could get to it was to come at it from the ones nearest to the interior. Very slow and tedious work, but I got them in. I imagine removal will be the same for you.
I should've mentioned that I had the ratchet coming in from behind the spring. Took some time, but it worked well.
Reason: Added to info
