1969 VIN Codes (part of a series)
Please Note – this is NOT going to be 100% accurate. Numbers changed, I coulda mis-typed, but this is the best I can do as a back yard mechanic to help you out. This came from 3 different books, and I tried to put all 3 into one page for ya. Please look for the book CORVETTE BY THE NUMBERS for more accurate information. Thanks.
1969 Corvette
DECODING THE VEHICLE IDENTIFICATION NUMBER
VIN # is stamped on the inside of the A pillar windshield.
Convertible Vin #’s were 194679S100001 TO 194679S138762
Coupe Vin #’s were 194379S100001 TO 194379S138762
Symbols, Letters and their meaning:
1st Chevrolet
2nd and 3rd Body Series (94 = Corvette)
4th and 5th Body Style (67 = Convertible, 37 = Coupe
6th Symbol indicates Year (9 = 1969)
7th Symbol indicates Assembly Plant (S = St Louis)
The last six symbols are the production numbers.
1968 – 1978 Corvette Trim Tag ID
Upper right corner is body build date
A = Aug 1968
B = Sept 1968
C = October 1968
D = November 1968
E = December 1968
F = January 1969
G = February 1969
H = March 1969
I = April 1969
J = May 1969
K = June 1969
L = July 1969
M = August 1969
N = September 1969
O = October 1969
P = November 1969
Q = December 1969
The Second and Third numbers were the day of the month that production of this car started.
On the left side is a word TRIM followed by the following:
STD = Black
407 = Red
411 = Blue
427 = Green
420 = Saddle
416 = Gunmetal
402 = Black Leather
412 = Blue Leather
416 = Gunmetal Leather
421 = Saddle Leather
428 = Green Leather
Just right of that is the word PAINT followed by the following:
900 = Tuxedo Black
972 = CanAm White
974 = Monza Red
976 = LeMans Blue
980 = Riverside Gold
983 = Fathom Green
984 = Daytona Yellow
986 = Cortez Silver
988 = Burgandy
990 = Hugger Orange
ENGINE CODES
1968 and 1969 consist of 7 characters:
1st is Assembly Plant
2nd and 3rd are Assembly Month
4th and 5th are Engine Code Suffix
Assembly Plants (Some engines produced at some plants were used in other cars.)
F = Flint Motor Facility (No Corvette Engine this year from this plant)
K = McKinnon Industries (No Corvette Engines this year from this plant)
S = Saginaw Service (No Corvette Engines this year from this plant)
T = Tonawanda
V = Flint Engine Plant High Performance
Engine Code Suffix ID’s
Code, Cubic Inches, HP, Transmission and Options
HY, 350, 300, Manual, Rochester 4 Bbl
HZ, 350, 300, THM400, Rochester 4 Bbl
GD, 350, 350, Manual, Rochester 4 Bbl, Transistor Ignition
HW, 350, 350, THM400, Rochester 4 Bbl, Special Cam
HX, 350, 350, Manual, Rochester 4 Bbl, Special Cam & A/C
LL, 427, 390, THM400, Rochester 4 Bbl, Hyd Lifters
LM, 427, 390, 4 Speed, Rochester 4 Bbl, Hyd Lifters
MH, 427, 390, 4 Speed, Rochester 4 Bbl, Transistor Ignition
MI, 427, 390, THM400, Rochester 4 Bbl, Transistor Ignition
LN, 427, 400, THM400, L36 Engine, Holley 3X2 TriPower
LQ, 427, 400, 4 Speed, L36 Engine, Holley 3X2 TriPower
MJ, 427, 400, THM400, L36 Engine, Holley 3X2 TriPower, Transistor Ignition
LO, 427, 430, M22 4 Speed, HD Engine, Holley 4 Bbl
LV, 427, 430, THM400, HD Engine, Holley 4 Bbl
ME, 427, 430, M22 4 Speed, Zl1 Performance Package (L88 Engine)
MG, 427, 430, THM400, Zl1 Performance Package (L88 Engine)
MR, 427, 430, M22 4 Speed, HD Engine, Holley 4 Bbl
LP, 427, 435, 4 Speed, Alum Heads (L71 Engine)
LR, 427, 435, 4 Speed, Mechanical Lifters, Holley 3X2 TriPower
LT, 427, 435, 4 Speed, Mechanical Lifters, Holley 3X2 Tripower, HD Clutch
LU, 427, 435, 4 Speed, Aluminum Heads (L71 Engine) HD Clutch
LW, 427, 435, THM400, (L71 Engine), Aluminum Heads
LX, 427, 435, THM400, Mechanical Lifters, Holley 3X2 TriPower
MS – Special built to customers order
Engine codes that started with M are Transistorized Ignition, added mid year. It required the K66 optional Transistorized Distributor.
Corvette Engine Blocks (You may have a different block, if so it might be from another Chevy Vehicle)
3932386 350ci, 300 & 350 HP, 4 bolt main
3956618 350, 300 & 350 HP, 4 bolt main (mostly used in lower performance applications)
3935439 427, 390 HP 2 bolt main
3935439 427, 400, 430 & 435, 4 bolt main
3946052 427, 430 HP, 4 bolt main, ZL1 Aluminum Block (Only 2 documented blocks ever used in a Corvette)
3955270 427, 390 HP, 2 bolt main
3955270 427, 400, 430 & 435 HP, 4 bolt main
3963512 427, 390 HP, 2 bolt main
3963512 427, 400, 430 & 435 HP, 4 bolt main
Cylinder Head
3927186 350, 300 HP, 1.94 intake 1.5 exhaust 63.305
3927186 350, 370 HP, 2.02 intake 1.60 exhaust 63.305
3927187 350, 350 HP, 2.02 intake 1.60 exhaust 63.995
3947041 350, 300 HP 1.94 intake 1.5 exhaust, 63.305 cc
3947041 350, 350 HP 2.02 intake 1.5 exhaust 63.995 cc
3931063 427, 390 & 400 HP, 2.06 intake 1.72 exhaust 100.967cc
3964290 427, 390 & 400 HP, 2.06 intake 1.72 exhaust 100.967
3964291 427, 435 HP L71 Engine 2.91 intake 1.88 exhaust
3919840 427ci, 435 HP, L71 Engine, 2.19 intake 1.72 exhaust 106.8 cc
3919842 427ci, 430 HP (L88) and below
3919842 427ci, 435 HP (L89) 2.19 intake 1.72 exhaust, 106.8 cc Aluminum Head
1969 Corvette
1st Chevrolet
A = Aug 1968
B = Sept 1968
C = October 1968
D = November 1968
E = December 1968
F = January 1969
G = February 1969
H = March 1969
I = April 1969
J = May 1969
K = June 1969
L = July 1969
M = August 1969
N = September 1969
O = October 1969
P = November 1969
Q = December 1969
STD = Black
407 = Red
411 = Blue
427 = Green
420 = Saddle
416 = Gunmetal
402 = Black Leather
412 = Blue Leather
428 = Green Leather
900 = Tuxedo Black
972 = CanAm White
974 = Monza Red
976 = LeMans Blue
983 = Fathom Green
986 = Cortez Silver
988 = Burgandy
990 = Hugger Orange
ENGINE CODES
T = Tonawanda
Cylinder Head
