Fan Clutch Question
Old 07-01-2006, 01:48 PM
ESC3
ESC3's Avatar
Default Fan Clutch Question
If I can hear fan noise at cruising speeds my fan clutch is shot right?
Old 07-01-2006, 01:57 PM
BarryK
BarryK's Avatar
best way to check your fan clutch is to bring the motor up to operating temps than shut it down.
If the fan clutch is working properly the fanblades should stop after between 1-3 revolutions.
If it spins significantly more than that or just keeps freespining for a while before it finally stops on it's own than your fan clutch is shot and it's time for a replacement
Old 07-01-2006, 02:08 PM
ESC3
ESC3's Avatar
How bout if it won't spin a whole revolution?Guess it's shot then too?
Old 07-01-2006, 02:12 PM
...Roger...
...Roger...'s Avatar
Generally the fan clutch will free wheel at cruising speeds.It is engaged and disengaged by temp.if it is staying engaged it could be a bad bimetallic spring on the font of the clutch or the radiator temp is really high.Does it free wheel at all when you shut it off,it could be locked up.
Old 07-01-2006, 02:13 PM
...Roger...
Can you spin it by hand?
Old 07-01-2006, 02:44 PM
ESC3
ESC3's Avatar
I can turn it by hand,but there is always tension on it.I am pretty sure it is original as well.
Old 07-01-2006, 06:48 PM
Duke94
Duke94's Avatar
I would say yes it's shot. My 71' did the same thing, fan roared during acceleration even when stone cold. Replaced the fan clutch, now I can hear the 4 barrel kick in!
To Fan Clutch Question
Quick Reply: Fan Clutch Question
