Help Decoding an Engine
I am looking for a little help in decoding a high perf 454. Here is the following information that I was able to find on the engine / in the engine:
- Block Casting #3999289, I couldn't find a casting date on the passenger side of the block.
- Heads 6272990 date code K-8 or 6 - 72, GM2T (I believe these are square port heads
- Intake 3963569
-Pistons TRW 3228; Cylinder pressures are 225 to 240 PSI - this blows my mind since the highest I have ever seen is 195 psi. I am thinking this motor has 11.5 or higher to 1 compression
- Engine Stamp Pad; T0615XCH, note no car serial number stamped
- 7/16" connecting rod bolts
- Pink / Dimpled Rods
- Steel Crank
Could this motor be an LS6?
Any help in letting me know what I have is appreciated. Thanks for your help.
Scott
- Intake 3963569
- Steel Crank
Scott
Cacsting 3999289 1972-78 454 2 or 4 215, 235, 240, 270, 2 bolt, car & truck
Heads 6272990 1970 454 Open 118cc service replacement mkIV
Couldnt find anything on the engine suffix, its not in any of my stuff.
T is Towanda plant
06 is month
15 is date
XCH should be the suffice? Maybe its XCE and its an engine replacement and thats why it doesnt have any VIN numbers???
T is Towanda plant
06 is month
15 is date
This is the same info I keep coming up with, 4 different websites say 454 2 bolt main
Received 1,469 Likes
Cruise-In II Veteran
My Chevrolet V-8 Engine Guide Book does not list an XCH code. It lists XC and XH, but no XCH. The XC is a smallblock. The XH is a 1968 396CID truck block.
I can look again, but the stampings are pretty clear.
Just for background, this motor is in a frame and I know for a fact that the car has not moved since 73 / 74. I took the pan off last night, I was shocked at how clean the inside of the motor was considering the car was in a barn w/ no air cleaner. By the look of it, it seems to met that the motor is a GM crate / replacement motor that someone just bought and put in. I can not find a date code on the engine though.
The cam is really radicle, and the compression is to the moon. I fogged the cylinders, changed the carb,oil, points condensor and the motor fired up which shocked me as well.
Thanks for your help, looks like I have an odd duck.
Scott
Scott
- Intake 3963569
- Steel Crank
Scott
- Intake 3963569
- Steel Crank
Scott
Received 6,943 Likes
2015 C2 of Year Finalist
5XC is a 85 454 and 2XC is a 1982 marine motor. the H could stand for Holley carb.
Location: About 1100 miles from where I call home. Blue lives matter.
Received 5,331 Likes
Hello nvr-enuf. Wondering if you found any details on this question?? I have the EXACT numbers on my newly acquired 1973 Corvette except the block stamp is T1212XCH. I couldnt find the xch suffix in any Chevy production motors and its very clear stamping. Is this an LS6 crate engine?
17 years later, probably time for a new thread.
