deluxe door panel question
Hello corvette friends I have just purchased a set of deluxe door panel carpet/ vinyl trim and they a kind of different to what I expected they seem to have a lot of excees materail that is tucked behind the carpet pieces has any one has this same problem?also what is the best way to attach these to the bottom of door panel? thank-you
St. Jude Donor '07
My original Deluxe panels had vinyl sewn to the bottom edges of the carpet then wrapped around the bottom and back of the door panel. You can't see it unless you stick your head down there.
