homemade tools part 2
Old 02-14-2007, 06:23 PM
bobs77vet
bobs77vet's Avatar
Location: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
Default homemade tools part 2
a couple of yrs ago i started a thread about home made tools and it circulated for a long time....so long it even got the first part of it cut off in the forum format switch. Comp kept it alive for a really long time so lets start it up again.....
this is an engine stand adapter i made for the flat head. flat heads are really heavy so i made this to hang it by.....and today we had really crappy weather and work was closed so i toyed around and mocked up a front engine support for the flat head... i will make another one for the other side. as usual the only criteria for this is that i have to have the the parts lying around....you can't see inthe photo but the bottom angle iron has a tab welded on the back side so it is held in place on the horizontal bar and can move from side to side....if i ever need to clamp it down i would use large band clamps.
i also moved the tool tray to up top that location of the "hook stud" ...it was horribly placed and you could pinch your fingers easily.....correction i did pinch my fingers.....
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
Old 02-14-2007, 06:36 PM
JoeRags
JoeRags's Avatar
Nice... whats the flatty going in?
Old 02-14-2007, 06:44 PM
bobs77vet
bobs77vet's Avatar
my 14 yr old son and I are working on a 37 ford hot rod project.....the vette was the car project with my now 19 yr old son, we started that when he was 15
Old 02-14-2007, 08:29 PM
C3 4ME
C3 4ME's Avatar
Looks like great work you've done there. I've always been curious about flatheads, never having worked on one, or even have any experience at all with them. I think it's cool to keep them in old hot rods, and not throw in a small block Chevy.
Old 02-14-2007, 08:37 PM
bobs77vet
bobs77vet's Avatar
they are really cool....i now see why people love them
Old 02-14-2007, 08:38 PM
JoeRags
JoeRags's Avatar
They are pretty cool... I have the 85hp flatty V8 for my '37 Ford sitting in the garage.... I'm replacing it with a 453 Detroit.
So much for the tool discussion
Old 02-14-2007, 09:26 PM
DR.Jay
DR.Jay's Avatar
Default Core support alignment tool.
I remember the Home made tools thread. It was one of the best. I missed it when it was lost.
So here is a pic of one of two that I made too adjust the core support, and hood alignment when bonding on the hood surround.
Big G gets credit for the idea.
They are made with;
36" long x 1/4 inch all-thread
36" x 1/4" id steel tube
2x 3/8" x 2" bolts
6x 3/8" id fender washers
2x 1/4" nuts
chevy door/fender shims
Weld the 3/8 bolt heads to one end of the tube, and a nut to the other end. Then screw the all-thread into the nut welded to the tube. Weld a shim to the other end of the all-thread. The shim end goes under the hood hinge with the hinge bolts tightened down,
The bolt end goes in the hood latch access holes (latches removed) with a fender washer installed on the engine side of the hole, and one on the cabin side, then screw two nuts onto each bolt, and tighten the nuts against each other.
This will allow you to push or pull the core support by turning the tube too adjust hood alignment when bonding a new upper hood surround to the car.
Old 02-14-2007, 09:50 PM
bobs77vet
bobs77vet's Avatar
thats a cool home made spreader bar
Old 02-15-2007, 08:24 AM
DR.Jay
DR.Jay's Avatar
I want to keep this thread going so.
TTT
Old 02-15-2007, 08:46 AM
bobs77vet
bobs77vet's Avatar
TTT
wheres Comp?
Old 02-15-2007, 06:36 PM
I'm Batman
Support Corvetteforum!
I'm Batman's Avatar
St. Jude Donor '07
Originally Posted by bobs77vet
wheres Comp?
ing threads in OT.
Old 02-15-2007, 09:07 PM
John 65
John 65's Avatar
Not exactly a tool, but made a nifty fold up workbench recently for the garage.
Old 02-15-2007, 09:19 PM
bobs77vet
bobs77vet's Avatar
thats a cool table does that brass colored thing hold it up?
Old 02-15-2007, 09:22 PM
shafrs3
shafrs3's Avatar
Good idea using that uni-strut brace.
[IMG][/IMG]
[/IMG][/IMG]
Old 02-15-2007, 09:25 PM
John 65
John 65's Avatar
Thanks, Yes its just a little gold latch, along with a door and some lumber I pulled out of the trash. Its pretty strong, a solid door with 4 hinges along a 2x4 ledger.
Old 02-16-2007, 06:30 AM
Jim Martley2
Jim Martley2's Avatar
I bought my wife new tires for her 93 for Xmas, romantic devil that I am, and I finally came up with something to make the wheel installation go easier. I have those metal shields that fit into the backside of the wheel to help keep the brake dust off of the face of the wheels and it completely blocks any chance of seeing where the wheel studs are in relationship to the holes in the rim. Add that to the fact that I am forever taking the wheels off to clean the car for shows and I only have a floor jack & jack stands to work with, NOT a fancy lift like SOME people and it gets to be quite a job that gets repeated at LEAST one a month in the show season. I just happen to have an old metal lathe in my garage and within 15 minutes I came up with this handy little stud extension. It helped cut SOME of the cursing & swearing out of the job !!
Old 02-16-2007, 11:45 AM
GlockGuy
GlockGuy's Avatar
Man that is a good idea. I think you have a MARKATABLE product there. Lucky.
To homemade tools part 2
Old 02-16-2007, 11:57 AM
Jim Martley2
I actually AM selling them. $15 each + $5 for shipping anywhere in the US. I sold a dozen or so to people from the C4 General forums and the racing/autocross forums. Here is a link to the original thread in C4 General. http://forums.corvetteforum.com/show...ght=Handy+tool
Old 02-16-2007, 07:03 PM
bobs77vet
bobs77vet's Avatar
thats a cool idea for the stud alignment.......I have never seen that before
Old 02-17-2007, 11:04 AM
GTR1999
GTR1999's Avatar
Received 2,618 Likes on 1,338 Posts
That Martley guy is always thinking!!! Now are you going to but a CNC to mass produce them!
Quick Reply: homemade tools part 2
