What is the value of a running #matching 1968 327 motor?
I have run across a 1968 327 corvette motor and I was wondering what the value is on it. At the very least the block and heads match or so I have been told. If I go look at it and it turns out not to be a corvette 327 what would the value of a 327 be? The motor is complete down to the brackets.
James
James
That is not a bad find. '68 327 has the big journals so it would be one of the strongest 327's ever built. The most journal overlap out there I believe. If it is the steel crank version it would be even better. With the right parts it would be an old school bullet proof RPM MONSTER Forged pistons, shaft mounted rockers, solid lifters, garage door valve springs, etc. That is the only way to build that engine IMHO. You have to want to spin it up to crazy RPMs. Drive it like you hate it.
-Mark.
-Mark.
Received 1,469 Likes
Cruise-In II Veteran
Without the '68 Corvette which came with it, it's just a smallblock. If the Corvette exists, and if the owner would like to have the original engine, then it has some value.
Does it have to be an exact #s matching? I thought there was a time window that was still acceptable as #s matching.
Will you take $600 ?
It probably has some value as a time correct engine and complete is nice. I'd say $500 assuming it's in good shape. Complete with Corvette intake, carb, distributor, brackets, etc a bit more.
It is for sale for 500 dollars. I wrote down some numbers for the different engine codes on a 68 327 So when I go look at it I can determine which motor it is.
The codes I wrote down were HE, HO, HP, and HT. I am guessing that these will be located on the passenger side near where the vin number is stamped.
If the motor turns out not to be a corvette 327 but is still a large journal 1968 327, how much would it be worth then? The motor is in running condition right now.
If it is just a 68 327 out of a Caprice it still has value as a hot rod core, just not as much. If it still sounds good to you, then buy it. Having the double hump heads to part out should seal the deal IMHO.
-Mark.
Seems real strange that every other collector car values a correct motor whether it's numbers matching or correctly dated a lot more than us vette guys.
I know that a correctly date coded non original motor will score higher than some junk yard block would and with all the correct parts included IMHO makes this motor worth a heck of alot more than $500.
Again just my opinion.
Just for the hell of it next time your at a judged show ask a judge if he thinks it's worth it to have a correctly dated non original motor.
NCRS will tell you 6 month window and a VIN restamp IS allowed.
IS allowed. IS !!
They don't really care if the exact same motor ... just that it is
the correct motor that would be installed at that time period.
That doesn't keep you from ridicule of other owners or wannabes.
So, no window on the VIN, 'cause you don't need one ... just $500 for a restamp.
IS allowed. IS !!
Most of the 350 available NCRS cylinder case points can be achieved from #1 - having the correct casting. Without that you get a 350 point deduct and thats the end of the points. If you have the right casting number, then they will look at the casting date of the block. If the block was cast after the car was built or more than 6 months before the car was built, you get a 175 point deduct from the 350 total available cylinder case points and the cylinder case judging stops there. If you have a casting date before the car was built by no more than 6 months and no later than the vehicle production date, they check the VIN/suffix stamp. The matching VIN/derivative stamp is last check at and is only a very small part of the total available engine points in an NCRS judged competition. They will deduct 25 points each if the VIN stamp or the assembly stamp is wrong in any way BUT the pad must not be obscured with rust, grease, or dirt. It needs to have visible factory broach marks, and no paint or paint (depending on model year). If it fails on any of those you loose 38 points from the 350 total available. Simple, right?!?!
Now matching VIN/suffix numbers on the block will have a more drastic effect on Vette PRICE at selling time but that is not on the table here unless there is a Vette that matches up with this particular engine floating around.
Not all that much fun if you ask me.
-Mark.
Well I went and looked at the engine today. It is the orginal engine that is in the car. The code on the front of the engine was HO which indicated a 300 horse car. It had an an automatic transmission as well. I did not look at any date codes because I decided that if it was not the HT code I was not going to buy the engine.
If anyone is interested I will send them the link where I found the engine for sale. It is located in Raleigh NC.
Thank yall for the help!
James
James
James
James
