Where to look for the VIN on the frame? Is it a stamp or is it engraved?
Pictures are welcome.
Clue
You're looking for the VIN derivative...same as that on the engine block in two locations both on the driver's side.
Look at the top of the frame rail where it kicks up in the rear fenderwell. You'll need a flashlight and mirror and may have to remove built up road debris. The other location is the back end of the driver's door under the sill plate cover. I'm not sure if this location is further rearward such that removing the sill plate is not sufficient to see it.
