Deluxe door panels question?
Hi all,
My 72 came with deluxe interior...I am gonna replace it....the orig door panels have the woodgrain and the lower carpet strip.
Q???...Can I get new door panels WITH the lower carpet strip, but WITHOUT the woodgrain insert? I think the woodgrain looks alittle cheesy, but I like the carpet strip.
I dont have my old door panels handy to check, but is the woodgrain piece simply "removeable"?
Thanks,
Rob
Thanks,
Rob
The "woodgrain piece" is actually a large metal plate with studs that go thru the panel itself, it also consists of a metal bezel as brightwork around the edge, and the simulated wood applique is applied on top.
You could look around for 1970 pieces, they used real wood veneer inserts and match the real wood veneer overlay on the center console as well. Not like the '72 fake plastic overlays.
Thanks, but my question was whether or not I could get NEW panels without the wood but with the carpet. I need to replace the entire panels, mine are pretty well shot..
Rob
Rob
Since no one is answering the specific issue, i`ll try. If your interested, I believe Al Knoch interiors can probably make the panels any way you want.....................
I purchased Al Knoch door panels and they come blank. You have to remove the delux trim from your existing door panels and transfer them over to the new ones. I believe no holes are punched so you can transfer whatever you want and it will work.
St. Jude Donor '07
Or you could try the '77 insert - it's black instead of woodgrain.
I bought a set of bare door panels - to install the Deluxe trim requires drilling a few holes. Personally, I hate that weird strip of carpet, so I'm going to leave it off.
Hi all,
Thanks,
Rob
Thanks,
Rob
On my 74 I liked the deluxe look with out the wood. So what i did was took my stock door pannels and from ebay got the chrome peices and carpet strips. Im debating on whether get the top chrome peice and fab up a brushed aluminuim insert peice. But Im still a few months away from the interior phase so i have time to deciede.
Hi all,
Thanks,
Rob
Thanks,
Rob
cc
Now there's an idea, how about covering the wood area with a panel of brushed aluminum or something?
St. Jude Donor '07
All door panels are standard panels, even from the factory. The Deluxe trim was added to the standard panels for deluxe cars. My 77s original door panels have the standard molding under the upper trim pieces.
Former Vendor
Received 1,813 Likes
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
You can order standard door panels and the carpet boots, and then just re-use your lower carpet moulding. It’s not too hard to do!
The easy way to do this would be as follows:
1) Test fit the carpet boot to the door panel, and make a mark with a grease pencil where the end of the boot extends.
2) Apply spray adhesive on the back of the carpet, then apply it to the door panel in area where the carpet is to be positioned. (3m fast tack trim adhesive works best)
3) Once the glue is dry, apply another thin coat on the back of the door panel carpet strip. Do this just like you would if you were using rubber cement. Then apply the carpet to the door panel.
4) When the glue is dry, pull the vinyl tight at the bottom and sides. With a good stapler install staples to hold in place. You can also glue this as above, but the staples seem to hold better for the long term use.
5) When done, re-install the lower carpet molding on the new panel.
6) Using the old lower moulding, push it against the door panel gently. This will make a mark for the first hole to be drilled in to the panel. Once marked, drill one at a time. As you come across the door panel you can mark the next hole after you have drilled the previous hole.
I've had problems in the past installing the lower carpet moulding. Trying to get those darn screws started is a problem sometimes. The issue is that the original screws do not seem to be long enough. So, if you run in to this problem, save the washer and run down to the hardware store and purchase some longer screws. Use these longer screws to draw up the moulding. As you go along, the moulding will pull in easier this way and the factory screws can then be installed.
http://willcoxcorvette.com/advanced_...s=carpet+vinyl
Thanks!
Rob
My '72 has a deluxe interior, which is correct per the trim tag.
What it does not have is any wood trim on the door or console.
The door panels do have the carpet trim across the bottom, so I've
always assumed they were correct.
I spoke with Al Knoch just this past week about a new set of
door panels. I was told the wood trim is included as they also
sell this item seperately.
I guess I'm still confused as to what should be on there.
Is the wood trim really that cheesy looking?
I was kind of looking forward to it.
This issue has been a source of confusion for me.
Former Vendor
Original cars from 1970-1976 that came with deluxe interior had the following: (All 1977 cars were deluxe interior and did not have the loop carpet as an option)
Deluxe door panels which included carpet at the bottom (with a vinyl boot to hold it in place), a chrome strip over that carpet with boot, an upper door panel plate which included a wood trim insert in it.
As pictured here.
The shifter console also had a wood trim that was installed on top of it. However, this wood trim often pealed off and did not stick to the shift plate very well.
As pictured here.
The sun visors on the cars also were the smooth and not textured visor as with the standard interior cars.
The carpet sets were all cut pile.
Only cars with standard interior had loop carpet and textured visors. Again, All 1977 cars came with deluxe interior.
Willcox Inc.
As pictured here.
As pictured here.
Willcox Inc.
