Body-Off Pics Anybody?
Old 07-14-2007, 12:04 PM
Emeightch
Emeightch's Avatar
Default Body-Off Pics Anybody?
I have all the mounts out and ready to lift the body. Can you guys share some pics on how you lifted the thing. Thanks!
Old 07-14-2007, 01:32 PM
gkz
gkz's Avatar
Sorry, it happened so fast I didn't take pics. I had to tie knots in my strap legs to take up the slack. My center of gravity was right above the wiper well, with the strap legs at the #2 & 3 body mounts. Search for threads; I asked this same question a few months ago and members posted some excellent pics.
Old 07-14-2007, 02:40 PM
Tankers
Tankers's Avatar
This is going back on, I used a small engine hoist that I bought. When I took it off I rented a bigger engine hoist.
Old 07-14-2007, 02:43 PM
jomor
jomor's Avatar
Best part about using ratchet straps is that you can adjust each on individually to level the body, as I found out here!
Old 07-14-2007, 05:29 PM
...Roger...
...Roger...'s Avatar
Thats an 8'6" ceiling.
Old 07-14-2007, 05:32 PM
tlynam
tlynam's Avatar
I couldn't figure out how to post pictures, so I added a body lift picture as my profile. If someone can fill me in on how to add pictures from a file as opposed to a web site, I can post more. Thanks.
Old 07-14-2007, 05:33 PM
tlynam
tlynam's Avatar
The profile picture didn't work either. I'm better with cars than I am with computers.
Old 07-14-2007, 06:25 PM
...Roger...
Go to Photobucket,download the pic,left click on IMG,right click-copy and then come back to your post and right click and paste
http://photobucket.com/
Old 07-14-2007, 06:48 PM
1ARACE
1ARACE's Avatar
I ran a strap inside by the rear of the door, a strap outside byfront of the door, and a strap for nose support.
I used a come-along ratchet to lift it, attached to a roller on an I-beam overhead.
When you lift and drop the body be extra cautious when the bottom of the rear quarter panels (left and right of the rear valence) clears the corners of the frame, it's a tight fit.
Old 07-14-2007, 07:42 PM
redwingvette
Support Corvetteforum!
redwingvette's Avatar
Body-off
Old 07-14-2007, 08:18 PM
ShinodaVette
ShinodaVette's Avatar
I would definitely be interested in more information on that contraption. I have to get mine back on one day and that could be interesting.
Old 07-14-2007, 09:10 PM
b71vette
b71vette's Avatar
Old 07-14-2007, 10:24 PM
...Roger...
Funny looking thing isnt it
I built that funky looking thing a looong time ago.I needed something I could haul and manage setting up by myself.I used to go to shops and peoples houses that were doing body offs and remove and reinstall the body for them.I could put the lifting jig on top of my Suburban the wooden body dolly inside and tow the engine hoist behind."The only traveling Corvette body lifter I knew of.LOL" Its just 2" tubing welded together.There are 2 steel straps on each side that are shaped to the body and curl up under and lift on the metal birdcage.I use several nylon straps to support the nose and the tail depending on the condition of the body and whether its a vert or coupe.I could lift the body high enough in an 8' 2 car garage to get it off the frame and then set it down beside the frame.Scary looking Huh ?
Old 07-15-2007, 07:53 PM
Emeightch
Emeightch's Avatar
Thanks Guys! I bought the straps and will go borrow the lift next weekend and let the fun begin. Looks like I'll also need to buy the body mount kit.
Should I label the shims & locations?
Old 07-15-2007, 09:31 PM
bj1k
bj1k's Avatar
Default 68 body lift without front clip
This is the method I used to lift mine without the front clip. I used a portable truck crane with lots of lift and had to use extra chains running down to the rear deck spring area for extra support and for leveling.
Old 07-15-2007, 11:44 PM
VetteThunder1
VetteThunder1's Avatar
Default This is my home made rig
Went down to Home Depot and got some 4x4's and had some 2x4's sitting around the garage. Picked up a come along at the auto parts store for half what Home Depot wanted.
It was easy enough to take the body off. I only had a problem with the mount behind the driver's door. The other 7 came out no problems.
Old 07-15-2007, 11:53 PM
Artsvette73
Artsvette73's Avatar
Thats what son inlaws are for
To Body-Off Pics Anybody?
Old 07-21-2009, 05:37 PM
1982CorvetteDude
1982CorvetteDude's Avatar
Has anybody done this w/o a lift and straps? Lets say with maybe 8 or more guys?
I'm thinking of rounding up at least 10 guys minimum to do this because I want to leave the car as complete as possible and not damage the nice paint or body....safety in numbers.
I'm getting ready to buy a replacement frame and only have a small 16" x 24" shop to work out of.
I have to plan the frame swap pretty strategically and quick.....hopefully sitting it on the new frame and back in the shop in a weekend. I can deal with the mechanics of it once it's back in the shop.
Old 07-21-2009, 06:12 PM
Alan 71
Alan 71's Avatar
Received 2,878 Likes on 2,515 Posts
Hi EM,
YES!!!! Be sure you count the shims in each location so you can get the same # in place when you set the body back on the chassis. It will help with door and hood alignment.
Regards,
Alan
Here's a picture that shows the #1 and #2 shim stacks taped in place as I was getting ready to put the body back on.
Old 07-21-2009, 06:20 PM
indy99
indy99's Avatar
Location: the land of a never ending frame-off resto-mod. May Visa have mercy on my soul.
Quick Reply: Body-Off Pics Anybody?
