cursed crossfire injection
I have a 82 with crossfire injection. I have replace most everything and still i get a stuttering from idle to about 2000 rpm. any suggestion. It also will not idle until completely warmed up. thanks
Wayne, Try www.crossfire.homeip.net that site has folks that specialize in the Crossfire and can quickly walk you through the typical problems and associated fix.
Read this
http://www.corvettefever.com/techart...ing/index.html
Did you also replace the Coolant Temp Sensor located up by the upper rad hose neck at the top front of your intake.
They're known to go bad and cause issues when cold.
B.....
B.....
