T/A Bolt cut where with Pics
Armed with CF and DC knowledge I tryed again to remove the T/A. Cutting seemed to be my only option. After 1 1/2 hrs ( includes rest breaks)and 3 Milwaukee saw blades later the dang T/A bolt was history. I laid the blade between the shims and just hung on. It was a PITA but after the T/A was out who cares. Thanks so much guys.
just wait until you take that cross member out that holds the diff.......
be there and done that....
keep pushing along
b
keep pushing along
b
use PB blaster instead of wd40....
if you plan on replacing the bushing.... just take a propane torch and heat up the bushing after the few days you pb blasted it........ then it should drop out......
if i remember right theres a num on the frame that the bushing slips over...once you have the cneter bolt out, you'll have to fight the bushing/rust thats creating the friction thats holding the bushing
b
b
Never try PB blaster. In fact that's the first time I heard of it. I looked it up on the internet and your right, it does have better features than Wd 40 . Thanks I going to get a can for the next time. And your also right about heating. The way that frame looks it going to need new bushing anyway.
Dan
Dan
CI 6 & 8 Veteran
I usually try to keep all the hype about "magic" sprays, cleaners, and lubes at arm's length, but in this case, PB Blaster does work very well as a penetrant. Heck, it even *smells* bad. No penetrant or cleaner is worth a @#$% unless is smells bad and/or burns your skin
local hardware/auto store
b
b
Thanks so much for all your help. I am planing to change the bushings. I will have to get a new can of PB Plaster. My can of PB plaster is almost empty. Good stuff . The frame is in very good shape. It is mostly surface rust. I don't know why the pics came out so redish.
charlie
The trick for the diff crossmember is after you take out the bolts holding it up, put them back in a couple of threads. Then you can use a gear puller between the crossmember and the bolt to pop it loose. The bolt also keeps it from falling to the floor when it does come loose.
i used a big azz pipe and was able to get some good leverage when i did mine......black gas pipe works the best
b
b
St. Jude Donor '08
I used a crowbar and came at it from the sides. Popped right out. Agree with remembering to put the bolts back in for a couple of threads, otherwise your diff will hit the floor.
WD40 sux, PB Blaster is ok, best stuff I have found is Moovit, I was in awe of it!
charlie
