fusor and cold temps
Old 02-22-2008, 06:02 PM
temvette72
temvette72's Avatar
Default fusor and cold temps
I am ready to bond my new front clip on and the weather is cold and damp (by California standards, anyway). Temps in the mid 50's and rain. Should I worry about using Fusor 127EZ in the cold, or will it be okay?
Temvette72
Old 02-22-2008, 06:49 PM
chris75stingray
chris75stingray's Avatar
it will take longer to dry (which might be a good thing when realigning the clip). it will also be thicker so you can let it sit in a bucket of warm water to it will flow easier from the tube.
Old 02-22-2008, 07:45 PM
wgbsigns
wgbsigns's Avatar
and you can heat set it with a heat gun after alignment. will dry fast then.
To fusor and cold temps
Quick Reply: fusor and cold temps
