Difference Between PO1 and PO2?
Old 02-27-2008, 02:02 PM
CCrane65
CCrane65's Avatar
Default Difference Between PO1 and PO2?
Can anyone tell me the difference between PO1 and PO2 hubcaps?
Also, I purchased a hubcap that looks exactly like a PO2 but it's smaller diameter. What the heck is that?
cc
Old 02-27-2008, 04:23 PM
dmayhew
dmayhew's Avatar
This is very rough memory , others will need to offer more details
But as I recall PO1 was in 1968 , the the P02 came out for 1969
I also think the wheels were different in 69 ,
Were the 68 Rallies 7" and then 8" in 1969 and later?
David
Old 02-27-2008, 04:29 PM
early shark
early shark's Avatar
The differences seem to be in the center cap design and in the thin blade design of the 'spokes'.
Yes, the ralley wheel was coded AG with rim width of 7" for '68 and coded AZ with rim width of 8" for '69.
Old 02-27-2008, 04:30 PM
early shark
cc
I believe that would be the Monte Carlo wheel cover.
Old 02-27-2008, 04:45 PM
0Road-Race Vette
Former Vendor
Road-Race Vette's Avatar
That is correct
Old 02-27-2008, 06:11 PM
CCrane65
CCrane65's Avatar
Thanks guys, at least I'll know what I'm selling.
Old 02-27-2008, 11:15 PM
CCrane65
CCrane65's Avatar
early shark and Road-Race Vette you are correct. I just did a search on Monte Carlo hubcaps and found a page with all the different ones and it was there.
Thanks again.
Old 02-27-2008, 11:22 PM
LYLE
LYLE's Avatar
cc
Are they 14". I have seen them before.
Old 02-27-2008, 11:27 PM
CCrane65
CCrane65's Avatar
Yes they are.
Old 02-28-2008, 08:46 AM
LYLE
LYLE's Avatar
Yes they are.
Not sure of the car but they were on other GM's not Corvettes.
Old 02-28-2008, 08:51 AM
CCrane65
CCrane65's Avatar
Ok, so another question. I have two PO2's with the flat center emblems. Why are all the Corvette Parts houses carrying only the raised PO2 emblems?
If I remember what I've been reading correctly, the flat ones are the Corvette only emblems while the raised emblems were for other Chevys.
cc
Old 02-28-2008, 01:21 PM
70BBvert
70BBvert's Avatar
cc
IIRC the flat centers were used on another car line, caprice or impala. The raised cap was for the vet. The same wheel cover was also used on the Riviera with a different center cap
Jim
Old 02-28-2008, 02:24 PM
CCrane65
CCrane65's Avatar
Jim
I guess I had it all backwards. The two hubcaps I purchased are the non-Corvette style.
Thanks for straightening me out 70BBvert. :o
Old 02-28-2008, 03:22 PM
Roughrider
Roughrider's Avatar
Another way to determine which is the Vette wheel cover...the center cap sticks out so far you constantly bang your shins into them!
Old 02-28-2008, 04:11 PM
CCrane65
CCrane65's Avatar
Boy, between whacking your shins on the center caps and burning your calves on the sidepipes these cars just aren't very user friendly!
cc
Old 02-28-2008, 04:55 PM
jaxlt1
jaxlt1's Avatar
Default P01 & 2's
Flipped upside down, they measure 16 1/2 inches across.
Old 02-28-2008, 05:27 PM
70BBvert
70BBvert's Avatar
Guess how I found out?:o
Jim
To Difference Between PO1 and PO2?
Old 02-28-2008, 05:33 PM
jr9170
jr9170's Avatar
Location: YANKEES UNIVERSE 70 454-LS5 500 ft-lbs Torque
Received 1,069 Likes on 755 Posts
But they sure look good.
Old 02-29-2008, 08:49 AM
CCrane65
CCrane65's Avatar
So, can I just swap the center caps for the Corvette style? The flat ones are attached with speed nuts on 4 posts through the hubcap.
cc
Old 02-29-2008, 09:45 AM
LYLE
LYLE's Avatar
cc
Yes
If you have the 15" flat style the corvette raised centers bolt right on.
I have found a flat style 15" cap for cheap sometimes and all the parts interchange to replace curbed parts or pitted spokes to make your Corvette set better.
Quick Reply: Difference Between PO1 and PO2?
