79 Corvette Dash (Help)
I'm working on a 79 L48 that has a few cracks in dash. My guess is the dash needs to be replaced. Can someone tell me what is involved in changing and replacing a 79 dash? What parts need to come out what can stay in? Is the dash 1 piece or 3 piece? The more information and detail the better.
Thanks,
-Dave
Thanks,
-Dave
The upper dash is one piece. The two knee pad dashes are screwed to the upper dash with three screws per upper edge. Very easy to get to. Next, remove the A-arm trim so you have more room. You'll want to start lifting in the middle, bowing it up, so the ends point down. Careful, you will have speakers to unhook, and a duct that mates with the defrost vent.
Once you get it slightly bowed, you can get it out fairly easily.
Or you can buy a dash 'cap' to put over the top of the dash you now have. It won't be completely original, but it will fix the damage on the dash quickly and look much better. Changing the dash pad is a PITA and will cost a bunch more than a cap. Good luck either way.
Unlike the earlier C3s, the 78-82 dash is ONE piece. You pretty much gotta remove EVERYTHING attached to it; both gauge clusters, glove box, radio and speaker connectors, AC ducts, wiper connection, headlite switch,etc., etc.........
The dash attaches with several screws underneath along the windshield. I think 2 screws at each door jamb. Remove the steering column support.
I've heard complaints about the fit of the repros so that will add to the frustration, too.
NCM Grand Opening Veteran
St. Jude Donor '11, '17
St. Jude Donor '10
St. Jude Donor '08
I put a repro dash in my '81 and it fit pretty damn good. Rather expensive but it looks great.
