Curtis74's new Vortec Engine
Well the time has come. Here is Curt's new engine, ready to swap into his beautiful 1974 Corvette. The car currently has a tired but clean L82 that runs good but lacks...bahls...
I found him a rebuildable long block out of a 1996 Chevy Tahoe. It's a 350, factory roller engine, with one piece rear main seal and better piston ring pack designs. The engine was bored to 355, and the pistons were replaced with flat tops for a rough final of 9.75:1 compression. The cam is an aggressive marine cam for Vortec engines.
The serpentine are F-body brackets, with some delete brackets and custom application pulleys. It looks like it'll fit okay under his after market Stinger hood.
Before it goes in we'll spend a day or two cleaning and looming the wires and vacuum tubing under his hood to make it all clean and tidy. Here is the car it's going in, and a few pics of the engine.
Swapping will commence this coming Monday.
Sa-weet! Is it going to be dynoed?
Curt will be keeping the headers and side pipes...we both love them so much on our cars.
Yeah we have a local chassis dyno and we'll be spending a few days out there running and tuning.
DB
Very professional work on that engine, I am impressed. I have a 74 also and really like curts car. That engine will make it not only awesome but now it will be bad $##
Location: Henderson Nv-Rohnert Park/Sonoma C o. ca/born in NY Rockaway Beach.
Holy crap matt...... I want one..... LOL
WOW....very very nice.... I would die for that motor... Man...Maybe you an break down whats on the motor..?? Im getting ready to start getting parts for my new motor... And would love to see the dyno results..
What trans is curtis going with?
Very nice job VERY NICE.......
Thanks so much for the compliment.
It's actually just as simple as the description at the top. Easy and simple are two things I like a lot, and I chose components that would get good results without breaking the bank or causing a lot of miss match situations.
The engine is a stock Vortec engine bored a bit, the heads are after market RHS Vortec heads, marine cam, factory roller, gear set for timing, paint, Vortec manifold, valve covers, and brackets. Simple.
I'll post all about the trip to the Dyno. Curt currently has a TH350 like I do, but will someday change to an overdrive transmission like a TH200R4.
Thanks, you'll learn as you go...that's what I did. I just jumped in and built my own engine. I knew nothing of mechanics before that.
Thanks, Curt and I both kind of came up with that. We wanted a way to put my name on it and so I had that plate made up. I fits perfectly and really compliments things without coming off as tacky...I think.
Thanks Miles! Are you going to make the trip up to Lake of the Ozarks next weekend for the Magic Dragon Street Meet Nationals? Durango Boy and I will be there. I know that's a long trip from Joplin..........
Miles
