Brake Caliper sealant
I am replacing the seals on my front caliper and my corvette book says to apply a sealant on the seals. I went to my local NAPA store and they told me never to do that.
Can I get some thoughts from the experts?
Thanks,
Tony
Thanks,
Tony
Received 1,469 Likes
Cruise-In II Veteran
redvetracr
Big difference..... Dust boots only.
Being cheap, I used what I had- anerobic sealer. RTV would work too. The anerobic sealer hardens in the absence of air- tight fit between the boots and the caliper, so I put a coat of it on. I didn'r want to open a big tube of RTV just to do the boots and then toss it next time I needed some after it set up.
As stated, lube the piston seals with brake fluid, install the boots and assemble. Are you using the lip seals or did you go to O rings and sleeved calipers?
