custom-autosound.com ??? New Head unit??
Does anyone have experience with the head units from www.custom-autosound.com?? They sell head units that look like the factory style but they are digital, have more power and have ipod hook ups. I am considering one of these systems and a new set of speakers. Has anyone done something similar or would you recommend something else? Thanks!
http://www.casmfg.com/Corvette_Radios.htm
I have never used one but I have high doubts about it's performance and others seem to doubt it's quality after having one installed.
First off, the only plus I can see is the design allows for the use of a stock bezel.
They claim more power, well, it might have more power than a stock head unit but that doesn't mean you can go out and buy new after market speakers. Even the best after market head units in the world only put out a realistic 17 watts RMS per channel...and I highly doubt the Custom Autosound unit does that. Maybe between 10 - 15 watts RMS per channel. That 4x60 is an over rated MAX output, and probably at 15V where most audio companies test their equipment.
If you're using it with stock wattage / resistance speakers, then you'll probably be fine.
If I recall, it has only one set of amp RCA outs, which means that yes an amp can be used but only for 2 channels. At this point, to utilize the amp's output, you WILL need better after market speakers to compliment the extra power.
This brings up new issues. First, firing up at the windshield is not a good way to position high power good speakers. It gets too 'bright' and will sound harsh and metallic.
Second, magnet size. People have had problems fitting 4x6" speakers with larger magnets in the dash. They do exist, but again you have to go back to the aiming.
Third, you cannot get mid-bass from a 4x6" speaker. Just not gonna happen. Most people prefer sound in the mid range, and stock size is just too small. In order to really get benefit from an amp, a larger speaker would be needed to get down into the mid frequencies.
It just comes down to what you want. If you really want to spend all that money for amplified highs then go for it. Personally a quality car stereo involves a bit of mid-bass and low frequencies. To do that you will almost always have to get away from the stock looks.
The signal level out of the rca's on lower grade radios suck and they are also usally .5 or 1v max where the average quality rca V output is 4v or higher. If you find a radio you like from anyreputable company contact me I'll be glad to order it at my cost and have it shipped direct to you.
I have the manual tune one [older model] and the sound out of the tuner is tinny. [no bass and the treble sounds flat] Based on what I paid for it I think you would be better off to buy an Alpine or Pioneer headunit [din] and buy a cutout instrument housing and go that route as you will be happier with the final outcome.
ok, so sounds like an after market radio is the way to go. Plus with and after market radio there are a lot more features. Im sure the quality will be better. Does anyone have suggestions on the speakers to use? Any pics from what people have done? I think the back has 6 x 9's is that correct? I have not taken the covers off to use. Can you put larger speakers somewhere else in the front besides the dash? I think it's really important to have a good sound system in a car like this, makes driving it that much better. And I also agree, it has to have good mid range and a little back bone to the music. Some low's.
Keeping it super simple yet very effective, and cheap.
Head unit
Amp on back wall or in storage compartment.
6.5" speakers in kick panels.
That's all there is to it. Done right and it'll sound amazing, and you won't have to worry with rear speakers, which in my opinion would only confuse your brain from an otherwise great front stage.
Head Unit:
http://item.express.ebay.com/KENWOOD...mdZExpressItem
Front Speakers:
http://item.express.ebay.com/POLK-AU...mdZExpressItem
Amp:
http://www.woofersetc.com/index.cfm?...roduct_ID=5219
Amp Install Kit:
http://knukonceptz.com/productDetail.cfm?prodID=KOL-AK4
Here are some pics.
I have installed both this system, and one with a larger amp and a sub. Both are extremely effective, great sound, even over the loud wind noise and engine roar.
Senior Member
Received 2,031 Likes
St. Jude Donor '10
Hope that helps a little.
David
77Sleeper
Senior Member
St. Jude Donor '10
Pictures Might Help Illustrate
I apologize for the missing carpet in this picture, just putting it in again now but here is the stereo in place. The wires are for the I-Pod and yes it has additional outputs for amps you want them, I opted not to use any additional amps.
This is the rear speaker box with 6X9 speakers giving the car much richer and deeper sound.
These are the Pioneer 4X6's I put in the top pad, perfect fit, great sound.
For what it's worth.
David
77Sleeper
1 Post
St. Jude Donor '09
My small input: I've replaced all the HU's in all my vehicles so far except the vette, I'm still working on Uncle Bubba's wiring, but I made sure all of them had front load USB ports instead of having a wire hanging somewhere for I-Pods or whatever.I bought some 8gig memory sticks for $50 apiece at newegg.com and have roughly 3000 songs on each one without getting close to maxing them out. Really easy access, no commercials.
FACTORY RADIO used a H/L
1 - AudioLink high/low adaptor "didn't need to remove radio"
2 - Pioneer 4x6's front kit panels
3 - Pioneer 4way 6x9's Rear drivers
4 - Sony 60 x 4 amp
build a small encloser with shared amp rack in middle and let me tell you. This car rocked man inside the car it sounded like there was a set of 10's took the thingfor a cruise top down at 50mph and it still sounded great .I mind U this car had Flowmasters. Now I have to re think my own system damn it . the whole setup ran under $600 and took a few hours with building the enclosure.
Let me tell you all I would do this system in another c3 without a question.
I did snap any .However after listen to it I'm going to build another duplicate set up for my ride 2maro. The enclosure was less than half the wieght of the 1 I was going to use,& alot smaller. So I'll have pics 2maro.
I've been piecing my console back together with a few changes. I installed a Custom autosound USA-2 with a small amp , 10" subwoofer, new set of 4x6 two ways up front and 6x9s in back.
Not a hard thing to do.
The amp is a 5 way, only 700 watts, 100 per speaker and 300 for the sub.
The USA-2 has four RCAs out, and two aux in for a MP3 player. It's far from a trunk rattler, but sounds about 10 times better than a stock set up and plenty loud to be heard over the side pipes.
Got about $340 in the whole thing.
John
John
Senior Member
St. Jude Donor '10
John
John
I'll have to give some thought to that amp set up on mine as well. I have about $220 in to mine +/- with the USA-2. I like it though.
Nice job.
David
77Sleeper
Exactly.
I used a similar unit. By the time I added all the other things to get it sounding right I was sorry I didn't go with something else. I wanted it to look as original as possible. FM sounds like crap. I use an MP3 player input source and nothing else. Ended up with a Swiss 4x 75 watt with 2 4x6 infinity dash speakers 6x9 infinity in back with a 120 watt MTX amp for a 10" MTX sub, Quite strong and deafining now, but so so sounding FM
Exactly.
