Pic Request: Battery Compartment
While swapping out the battery in my 72 I noticed the battery was being held in place by a 2x4 and a piece of styrafoam. Since very little of this car hasn't been "bubba'd" I'm looking for a nice picture of the way the battery compartment should appear.
Also, did these cars come with a holddown of some sort? When I remove everything I can see two holes in the bottom of the compartment that I can see the ground through. Should there be some sort of plug?
Any pics would help. I'd like to fix up as much as I can.
Towards the front of the batt compartment there should be a metal bracket that catches the lip on the bottom of the battery. I appears to be rivetted in place(?). To the rear of the compartment (behind the battery) there should be a threaded hole in the middle. There's a hold-down bracket that also catches the lip on the bottom of the battery and gets bolted down via this hole.
Back in the old days (60's & 70's) before maintenance free batteries they had 2 vent tubes that ran down and exited underneath the battery
I think there was also a hole with a rubber plug in the center
thanks so much, that answered everything I was wondering.
One last thing: where does your ground cable attach in your cars? Mine is attached next to the front reinforcement so it's in the way of the battery. Where SHOULD it be grounded?
