fuse panel
fuse panel
Is the fuse panel layout on an '81 the same as an '80? I have a diagram for an '80, but I own an '81. The labeling on my fuse panel is worn off on most of the fuses.
Received 1,469 Likes
Cruise-In II Veteran
Do you have an owner's manual or the assembly instruction manual (AIM)? If not, order both. Fuse block is almost always shown in the owner's manual; it's also in the AIM, but the diagram is not as clear as the owner's manual.
