1979 Corvette Fuse Box
Old 10-03-2008, 02:09 PM
spiritdancer18
2nd Gear
spiritdancer18's Avatar
Default 1979 Corvette Fuse Box
Where is the fuse box located and is there a diagram for the fuses? Is there a guide to fixing the windows? They barely work. The door locks are sticking as well....help!
Old 10-03-2008, 03:19 PM
Wuttin
Wuttin's Avatar
Located on the firewall up above the driver side kick panel (below the dashunder the light switch).
If you're new to the C3 and the 79 you'll find a copy of the AIM (ie Assembly Instruction Manual) to be real useful. There is also a forum member offering pdf's of year specific wiring diagrams if you just send him an email. Helps alot. Don't remember his member ID so hopefully someone else can chime in.
Best of luck
The following 2 users liked this post by Wuttin:
dhmuhammad@gmail.com (01-21-2021), Zuhair (07-01-2022)
Old 10-04-2008, 01:13 PM
spiritdancer18
2nd Gear
Thank you so much for making my job easy!! I love forums !!!
Old 10-04-2008, 05:27 PM
joshtried
joshtried's Avatar
St. Jude Donor '08-'09-'10
his name is papawana,
but he sent me a lot of stuff 79 specific. if you want any of it, pm me your email and ill send what ive got
Old 10-04-2008, 05:59 PM
C3 4ME
C3 4ME's Avatar
One of the best things you can do for working on the electrical system is get yourself one of those laminted posters of the wiring diagram. I belieive it's Lectric Limited where I got mine from. It's tacked on the garage wall right on front of where the Vette parks and I refer to it a lot.
The following 2 users liked this post by C3 4ME:
dhmuhammad@gmail.com (01-21-2021), Fastclient (03-13-2020)
Old 10-05-2008, 07:57 AM
papawana
Support Corvetteforum!
papawana's Avatar
Received 1,121 Likes on 321 Posts
Default wiring diagram
pm me your email address and I will send you everything I have for your '79
Old 10-29-2009, 07:07 PM
TheSkunkWorks
TheSkunkWorks's Avatar
Location: Graceland in a Not Correctly Restored Stingray
I ran across this while searching for a retrofit blade type fuse center for my '78 other than those universal aftermarket types. Guess I never stuck my head under the dash of a '79, as I was not aware the blade type fuse panel had apparently become adopted as early as that year. My question is, has anyone retrofitted a '78 with this?
edit - Anyone who wishes to reply to this post should PM me, as I've cancelled my "subscription" to it as of this edit.
Old 10-29-2009, 10:30 PM
swtato
swtato's Avatar
St. Jude Donor '05
I agree the barrel fuses SUCK!
Old 08-23-2010, 09:11 AM
daniel2020
1st Gear
daniel2020's Avatar
Default hey mate
dandaman69er@hotmail.com
hey mate just bought my 79 and still wounder about little things like the aerieal is it elctric and if so where the switch and and little things like that if u had like a owners manual or something like that that would solve all my little drams lol thanks mate wouldbe greatly apprectiated
Old 08-31-2010, 07:42 PM
zestay
zestay's Avatar
Old thread revival can someone email me this 79 stuff as well ?
Supertaco@gmail.com
Old 11-17-2011, 10:59 AM
Ramonabiker
Navigator
Ramonabiker's Avatar
I just bought a 79, and can't figure out why the turn signal/high beam lever on the steering column wont work. Anyone have any idea??
Old 11-25-2011, 08:33 AM
Mahboob
5th Gear
Mahboob's Avatar
Default 1979 wiring
Hi do you have the wiring diagrem for 1979 I have problem with my gauges light and turn signal light not working can you help me. pleas my mail is mabonly@yahoo.com
Old 11-28-2011, 11:43 AM
papawana
papawana's Avatar
Default wiring diagrams
diagrams sent
Old 12-12-2011, 10:19 PM
zc31
1st Gear
zc31's Avatar
dropped a penny in the lighter unit n dome light went out which fuse is for the dome light
Old 12-13-2011, 06:48 AM
papawana
papawana's Avatar
here is the 1979 fuse box diagram
Old 12-14-2011, 09:54 PM
leah4185
Cruising
leah4185's Avatar
I had to get to the fuse box on my '79 too. It's way up under there. I felt like a contortionist twisting around and laying with half my body hanging out the car just to get to it. I accidentally hit my face on the steering wheel twice just by turning my head. Then again, I'm just talented that way.
Good luck with the windows and door locks!
Old 12-15-2011, 01:05 AM
Mahboob
5th Gear
Mahboob's Avatar
Default Wiring
Thanks it was very help made my work very easy
To 1979 Corvette Fuse Box
Old 02-03-2013, 03:24 PM
VetteMayer
VetteMayer's Avatar
I just bought a '79 Vette and have all sorts of small issues. While reading through the forum I see you have some items that could be of use for the '79. Any chance I could my hands on those resources as well? None of my flashers work (turn or hazard), when I press the brakes the marker lights get brighter, my dash lights worked for a short time now they don't, and the list goes on and on. In fact I opened the kick plate on the drivers side and saw red wires simply cut but have idea what they do to or what they are for! I've got a real project on my hands here.
Thank you in advance for any help I could get.
VetteMayer
Old 02-03-2013, 03:27 PM
VetteMayer
VetteMayer's Avatar
my email address should anyone have ANY resources I could use for my '79 Vette is as follows: mayer2247@gmail.com
Once again, thank you to everyone in the forum!
VetteMayer
Old 02-03-2013, 04:58 PM
papawana
papawana's Avatar
VetteMayer
diagrams sent
Quick Reply: 1979 Corvette Fuse Box
