Fiberglass Rear spring failure MFG?
I bought a 75 vert.a few years ago with a fiberglass rear spring. I was changing oil today and I was checking the U-joints and found the rear spring split open on one side about half way through. The numbers on the spring are 602-101-10-105 serial #033790. I see no mfg information but it could be on the top. If you have a spring near this number it could fail. This spring looks new and had heat shields in place above it. Would anyone know who made it? I will post pic. soon.
Lyle
Lyle
C6 the C5 of tomorrow
IIRC if it is wider at the tips than the center it was made by Muskeagan brake,
http://www.muskegonbrake.com/v4/go.g...&listTemplate=
Now I can't remember who makes the other style...
Do a search or the archives
Sounds to me like a TRW.... I have a spring with numbers like those, but I am not sure if they are the same or not. I do know that my spring is a 340 and that it came with a heat shield.
That is a TRW 340# spring. I have the same unit on my car. No issues in over 10 years use.
BTW, the part number is actually 602-103. They put a sticker on the spring that says 602-101-103-105 and then punch a hole at the number that corresponds to whichever rate that spring is.
101 = 315#
103 = 340#
105 = 355#
101 = 315#
103 = 340#
105 = 355#
101 = 315#
103 = 340#
105 = 355#
101 = 315#
103 = 340#
105 = 355#
And I believe that TRW was the original manufacture for the spring when it came out on the 80 or 81 I don't remember which year.
St. Jude Donor '08
101 = 315#
103 = 340#
105 = 355#
101 = 315#
103 = 340#
105 = 355#
Not as low as some but I like it.
That was on a 80 I was working on for a friend. The 75 with the broken spring had it when I bought it so I didn't know who made made the spring or if they would replace it. I don't know when it broke but I have put about 1000 miles on it.
If they do break, VB&P would do right by you, they stand by their stuff
