Big block pulleys and brackets
Is there a place to get the pulleys and brackets for an early 70s big block without missing a mortgage payment? A fairly nice big block "fell in my lap" but I don't want to spend a fortune making it work.
Senior Member since 1492
That triple groove crank pulley was very $$ when I was building mine.
Still seems to be
The cast iron power steering pulley caught my attention too. More than anything though, it seems to be the accumulated cost of the various parts rather than the cost of any individual one.
pick a vender and order the complete setup.
I ordered my thru Davies corvettes, not cheap but I received the correct parts.
69VETT
69VETT
keep in mind the early power steering pumps used a smaller dia. shaft.
the early cast pulleys only fit the early style pumps.
also the brackets are specifically for BB only. 69VETT
If you're not worried about originality, go to the junk yard and look at GMC buses and 1 ton pick up trucks. They may not be correct for Corvette, but they'll keep the battery charged and the wheels turning free. You should find what you need dirt cheap. Just don't get stuff from a 366 big block or a 427 tall deck. Very differant set ups on those engines. All the 454 stuff should work.
Hey 69vette! It looks like your alternator belt needs adjusting.
Not to hijack thread to much but could someone possibly throw up a pic or two of the proper BB A/C brackets as well for the original posters yr.
ikwhite
ikwhite
I don't think 67-68 Camaro parts are the same, and I know 69 is different. Chevy went to the long water pump in 69 and moved the alternator to the passenger's side.
.....with air conditioning..
......without air coditioning...
...The Vette..
All 3 Photos are OE in every respect. No hot rod stuff, absolutely pure factory stock parts...
Ironcross,..I don't know what brackets or cars those are, but it's not origianal 69 Camaro stuff, or Chevelle or Nova. One of the brackets looks to be from a truck. Here's a 69 Camaro:
http://s421.photobucket.com/albums/p...t=PB030002.jpg
A/C doesn't matter. Go to page 82 & 83 of the 69 Camaro Assembly Manual for further verification.
In 69, Chevy switched to the long water pump for everything but the Vette which didn't have the room. No way the bracketry from a post 69 will work.
