Show us your custom tools, improvements and fixtures to improve the hobby
Old 11-01-2008, 11:53 PM
Blain
Blain's Avatar
Default Show us your custom tools, improvements and fixtures to improve the hobby
So, we have seen garages, girls, flares and sidepipes.
How about those creative tools you have fab'ed up? Jigs built to hold stuff or improvements to junk tools?
I'll start;
Here is one of those import presses seen in several threads on the forum. Problem is they are shipped knocked down. When bolted together it just isn't tight. But a few minutes with the ol' Miller Mig does the job
Where do you park the engine stand when the engine is finally in the car? Turn it into a flourecent light stand! About $8.00 of chain link fence parts and a discarded 4 foot light fixture.
Share those things you have done to make'em better, stronger, faster!
Blain
Old 11-02-2008, 12:19 AM
earthquake68
earthquake68's Avatar
I'll get some shots of my transmission service stand. I was tired of propping up the trans with bricks or whatever was handy to work on the valve body, then leaning it against a table to set the clutch assemblies in, so I made a real cool stand to hold the trans still while I work on it. It'll even hold a trans suspended straight up and down to set the clutch assemblies in. It works nice.
Old 11-02-2008, 09:29 PM
Blain
Blain's Avatar
Come on, don't hide your stuff.
Old 11-03-2008, 12:24 AM
stinger12
stinger12's Avatar
Homemade sandblast cabinet...
Homemade trailing arm bushing tool...
Homemade u-joint flange backing plate...
Homemade tool for fixing collapsed u-joint flanges...
Old 11-03-2008, 12:34 AM
KTKelly
KTKelly's Avatar
I'd be afraid my plumber friend "Bubba Butt" would become confused and bolt a couple toilets onto that cabinet...
Old 11-03-2008, 08:44 AM
thegazman
thegazman's Avatar
Default thegazman
I'm impressed with "Stinger 12"s u-joint flange backing plate. It would saved me from buying a new backing plate. Wish he was my next door neighbor instead of our neighbor to the north.
Old 11-03-2008, 08:59 AM
lock-n-load
lock-n-load's Avatar
I built something like this years ago to change the babies diapers ...
Old 11-03-2008, 09:47 AM
VETTEVIC
VETTEVIC's Avatar
Sure i'll give it a go
A piston stop for finding TDC. Spark plug anti fouler drilled out and tapped to fit a bolt that has been rounded and smoothed on the end (adjustable).
A rolling body dollie made of lawnmower parts, low to ground and steerable with pneumatic tires. Sat on it for 2 years, lol, and low to ground for clearance in any garage.
Also, not shown, a lathe turned rear spindle for setting bearing preload, various push clamps for tranny repairs (internal), a slip on steering rod for moving the frame around without body, cam bearing tool, and a few more I dont recall at the moment.
Old 11-03-2008, 11:55 AM
Blain
Blain's Avatar
Now thats what I'm talkin' about.
I expect blueprints in the morning.
Blain.
Old 11-03-2008, 03:52 PM
Bowerss2
Bowerss2's Avatar
i built a custom coil spring compressor to better fit the suspension of my 80. it works a million times better than a normal coil compressor, made it out of some acme rod, and some other welded parts, will take pics of it when i have time. Nice custom tools btw!
Old 11-03-2008, 11:39 PM
Blain
Blain's Avatar
Must be some more out there......... Fess up.
Old 11-05-2008, 11:53 PM
Blain
Blain's Avatar
Anyone?
Old 12-10-2008, 02:11 AM
SUPERPOWERS
SUPERPOWERS's Avatar
another use for an engine hoist and some tie down straps
Old 12-10-2008, 11:19 AM
Blain
Blain's Avatar
Aren't ratchet straps WAY better then the body lift straps?
Blain
Old 12-11-2008, 04:55 PM
usa#1
1st Gear
usa#1's Avatar
When using ratchet straps for a body lift, where are the straps connected to body so there is no body damage?
Old 12-12-2008, 11:55 AM
Blain
Blain's Avatar
Same place as the fabricated straps. The hook grabs the birdcage channel at mount #2 and #3. The strapping material itself comes into contact with the body and not the metal part of the hook.
I found the fabricated starps require too high of a lifting point. the ratchet straps can be adjusted to shorten that point. You can buy 4 of those for about the same $$ as the body lift harness. Afterwards they have multiple uses whereas the body harness does not.
Blain
Old 12-12-2008, 01:13 PM
lakerider57
lakerider57's Avatar
So I was wondering whether you had to remove the glass before the lift, I see you didn't - I would of thought it would have cracked.
To Show us your custom tools, improvements and fixtures to improve the hobby
Old 12-12-2008, 01:51 PM
Blain
Blain's Avatar
I didn't position the straps the same as SUPERPOWERS. I routed behind the windsheild and in front of the targa roof. I know, its not a targa but I don't know what to call it.
Blain
Old 12-12-2008, 02:21 PM
SUPERPOWERS
here are some pics. This is way better than using the strap kits. The adjustability is great, I bought 2 of each type if strap and combined them. (look at the ends of the straps) And then bought some d-rings at the local farm supply store.
Old 12-12-2008, 06:13 PM
cargo247
cargo247's Avatar
Small tool but a good one for me. Antenna wrench
Made out of adjustable grinder pin wrench, just ground the pins flat to fit. works like a charm and no paint damage
Todd
Quick Reply: Show us your custom tools, improvements and fixtures to improve the hobby
