Kick panel reinforcement
Old 03-06-2009, 06:42 PM
tsm75
tsm75's Avatar
Default Kick panel reinforcement
I'm getting ready to install Polk db 651 speakers in my kick panels. The panels are kind of "flimsy".....what can I do to reinforce them?
Old 03-06-2009, 06:58 PM
temvette72
temvette72's Avatar
I have seen people use a kit from Dynamat to reinforce the kick panels. It is a speaker mounting kit that has a couple square feet of Dynamat for around $20.
Temvette72
Old 03-06-2009, 07:26 PM
Paul L
Paul L's Avatar
Dynamat along with a little JB Weld in the weak areas will take care of things. Those speakers won't move nor crack the panels.
Old 03-07-2009, 11:13 AM
stevekk
stevekk's Avatar
I took the "plastic ring" that came with the Polks and glued them to the backside. Also this gave me a pattern to make my hole.
Old 03-07-2009, 11:23 PM
7T1vette
7T1vette's Avatar
Received 2,713 Likes on 2,271 Posts
It would be best to mount the speakers to the [metal] body panels instead of the plastic kickpanel. It will be mounted firmly and the speaker won't be 'wigglin in the wind'. Add some fibreglass sound deadener behind them and put the kickpanel over them. Or, if you need, you can cut a clearance hole in the panel, too. Just my .02.
Old 03-08-2009, 09:27 AM
Red Rochester
Red Rochester's Avatar
Temvette72
Old 03-09-2009, 07:00 AM
Ganey
Ganey's Avatar
Correct.
A plate should be made to separate the front waves from the back. With a plate & 3 screws tight into metal & one loose the sound is better after tightening the 4th! The energy should be put into moving the speaker cone not the panel.
To Kick panel reinforcement
Quick Reply: Kick panel reinforcement
