Big Block and Small Block Frame differences?
Maybe a silly question, and I talked to someone else in my parts.. and they said that Big Block Chassis are different than Small Block Chassis?
I always thought they were the same?
The way the engines are positioned, it appears that the big block is far larger than small block (instead of only incrementally larger). The centerline of the crank is higher off the ground for the big block which lends to this illusion.
It's interesting comparing the 435 motor in my 67 with the LT5 in my 95 ZR-1. Those DOHC heads really make the LT5 appear huge, even compared with the big block.
I'll hook the SBC up to the crane later today and shoot a picture with the two at the same height as that should give it a better perspective.
I measured and the center line of the crank is 2-1/4" higher on the big block as pictured. If I had another engine stand it would be a better comparison, but it is certainly substantially bigger. I can tell you it weighs a lot more! My engine crane can sure feel the difference! That is why the front springs are difference between the SBC and BBC versions.
I have also heard that those were Corvairs and not vettes.
Do you have pics of your old car? Just curious to see it...
Well, see, I HAD pictures, and a bunch of paperwork too, but they were all destroyed in the fire. Tragic story about a pet pig gone wild at the sight of a mouse living under my couch....suffice it to say that we are just happy that everyone got out in time. Well, except for Poo-poo my pet turtle, God rest his soul.....
On earlier C2's (pre big block) the front crossmember is different where the lower pully's and balancer are, dont know if early C3's are the same or not, but probably not cause big blocks were always available for them. Peace,,,Moosie
cc
Pictorial C2-C3 frame history always worthy of note when these questions arise...
http://www.71corvette.com/frames.html
PKguitar, of course, now someone out there is probably thinking about "cloning" that '58 BB (in 'glass), so if one shows up on feeBay for some ungodly amount we'll be holding you responsible.
TSW
TSW
Ha ha
what an idiot!
but they do keep us laughing....
Sully
Yep. I had an 83 Vette that was all aluminum. Well, except for the engine. That was fiberglass. A really rare machine.
