Need new badges, opinions/recommendations??
I'll be getting my 82 painted next month.
I have the old Cross-fire-injection badges (they will need to be removed).
I have a zz383 and will be installing a new L88 hood. What badges, if any, should I use?
And where would you guys put the new badges?
Also any tips or suggestions as I disassemble the car before I take it to the painter?
Location: 406ci SB, AFR 180 Heads - 490 HP @5,600 RPM 529 lb-ft @ 4,100 RPM
You will have to fill the holes anyway, drill new one's for the flag emblem, the pin holes in the crossflag are different from crossfire. When I had my 79 painted I removed and filled the L-82 emblem holes in the hood, because I dropped in the 406.
Did you do any re-badging (406) on the hood?
Since I can't think of anything tasteful, none may be the best option!
