Hydroboost install complete with pics
I finally got to take my '80 out for a spin with a Hydroboost hydraulic brake booster yesterday. I like the feel of HB brakes SO much more than a stock vacuum booster. Total cost of the project was about $300.
I've got to give credit to our son, Matt. He put a HB booster on his friend's Camaro and applied what he learned to my car, especially for connectors, hoses, and routing the lines. The end result looks great!! See for yourself:
Here is the installed booster and MC from the left:
and from the right:
Here are a couple of pics showing how the lines route over the Steeroids u-joints:
Keeping the lines high and tight-left keeps them as far from the headers as possible too:
Matt is a CNC machinist. He annodized the custom aluminum mounting plate and engraved the top edge. Nice tough:
and from the right:
Very nice and neat job.
I really like the hose routing. I also like that you used stainless rather than rubber for the return line. I did the latter and plan to go back and redo it. Works fine but I like the look better with all stainless.
76CSRvette (07-15-2016)
When you use a hydroboost, does the MC end up in the same place it was when connected to the vacuum canister? In other words, will the MC brake lines exactly match up to the holes in the MC just as if it was still with the vacuum booster?
I made no changes to the MC or brake lines whatsoever. I didn't measure, but I think the HB and vacuum boosters are the same depth. I will measure tomorrow to let you know for sure.
Looks very nicely put together. This is one of the things I have been wanting to do to my vette for a while. I like the cost of your project. Is the hydraboost a junkyard unit or any details would be appreciated?
Yes, Matt machined the mounting plate. The mounting plate is the most important part of the conversion because that is what maintains the functional length of the rod from the pedal to the booster.
The Hydroboost is a $50 junkyard unit from a late-90's 3/4 ton Chevy pickup. Yes, Matt did an excellent job with the whole setup. He spent a lot of time measuring for the plate, mocking up the hoses, choosing and shopping for the right connectors, etc. That is his signature.
Eddie, let me know when you're ready to convert.
Hydroboost gives a whole new meaning to braking on a C3. It is one of the most inexpensive enhancements you can make. And like Eagle says: you will STOP and darn quick and easy!
C3 Hydroboost
C3 Hydroboost
I’m not sure I understand…..I’ll agree your mounting plate looks nice, but I cant see how it works any better than others. I’m not trying to be negative here, but there are lots of people who will want to try the conversion and the thickness of the plate would only affect the position of the adjustment nut on the clevis. Or am I missing something?
Not the best picture, but the plate on mine is only 1/8” thick.
My Hydroboost unit was missing something - an adjustment nut. The Hydroboost unit I got from the salvage yard (the last one they had) has a fixed length clevis. It was easy to make the plate the thickness needed for the HB clevis length to be the same as the vacuum booster.
Hose routing
