Wiper Door won't go down
I finally fixed my wipers (after 5 years of not working) and now the wiper door won't go back to the 'home' position. I checked all the hoses, and they all look right. The by-pass under the steering column is in the correct position. Any ideas? Is there a 'home' switch on the wipers that will tell the door it's OK to go back?
Received 1,469 Likes
Cruise-In II Veteran
Bad relay.
Sounds like it's sending vacuum for the open operation and not sending it for the close.
If you need some further testing to confirm your problem let me know and I can walk you through it with some pinch testing to isolate your problem.
There is a "interlock valve" that prevents the panel from closing untill the wiper arms are safely parked. Check to make sure this valve is working and not cracked and make sure the 3 hoses are installed.
here are some pics of the Valve.
