best custom c3 pics
Billy, are those Z06 seats in your '69? How hard was it to install them? I'm thinking of a seat upgrade and those look GREAT.
shmoky
They were pretty easy,the seats are just a little wider then stock seats.These seats are ALOT more comfortable then the old seats,they suckAll i did was the unbolt my old seats from their sliders and put the slider bolts back in the seats,then i pressed the old seats down on a sheet of cardboard and made the impressions of the bolts from the bottom of the seats on the cardboard,then i cut the cardboard to size and put it to the bottom of my zo6 seats and marked the spots were the bolts were from my old seats and drilled and tapped holes.Centered everything up ofcoarse.Then i bolted the old sliders on my zo6 seats and bolted the seats in my car. Did i explain it ok? Oh yea,you will have to put about a 1/4 inch spacer between the z06 seat and sliders ,washers will work,for clearancing.I will be changing my interior color to black and gray.
St. Jude Donor '09
[QUOTE=tristan69;1571393080]I love it!
Where did you get the Corvette door insert and steering wheel?
Here are a few of my custom '74[/I][/B]
Thank you,
The door panel has a deluxe insert that was stripped and painted and then a "corvette" decal on top. The steering wheel was custom made by dallas custom steering wheel.
Thank you,
