81 Headlights Won't Turn On
Cruising
I have an '81 and my headlight will raise just fine and all the marker lights come on fine, but no headlights. I didn't see a fuse, any idea what the problem might be?
Does the highbeam indicator come on when you flip the dimmer switch? If so that at least tells you power is getting to the dimmer switch (assuming your 81 is wired the same as my 80). There's a self resetting circuit breaker which should only be open in the event of an over heating condition. The other things to check would be that each light is properly grounded.
Cruising
Thanks for the responses, I have no lights at all, high beam or low. I get no indicator when trying the high beams. I don't htink it would be a ground problem, one day they were working and then not. Where are the fuseable link you'all are talking about?
Here is a fusible link on Duke94s car. The short brown wire in a loop is the link. Its running between the 2 large red wires. The large black plastic pieces have crimp connectors inside. The wire inside the brown covering burns in 2 , so you have to pull on it to see if it stretches. On your car at the starter you will have 2 fusible links,one for the headlights and one for the rest of the car. Your links might be black in color.
1 Post
I had a similar problem years ago with the 78, the headlights got dimmer as the evening wore on until they went out completely. Got pulled over, but the cop was cool and let me head home (the high beams did work).
Turns out the wire from the back of the fuse box through the firewall was going bad...
If it goes bad again, then you got a bigger issue somewhere in the circuit.
I have an '81 as well and now I just learned something else about it. Nice to know.
Hello, all!
That's fantastic, ALNDD!
Not to hijack this thread, but some might have a similar problem...
The high beams don't work on my '81. No power to the high beams and no high beam indicator. The low beams work fine - but, when I click to high beam, they go out! Shouldn't all four lights come on in "high beam"?
I'm thinking I've a bad high beam/dimmer switch. Would you all agree?
Thanks! ...Alan K.
Thanks! ...Alan K.
Hello, all!
Thanks! ...Alan K.
Thanks! ...Alan K.
This a 78 but will be the same for the dimmer.
http://www.corvetteforum.net/c3/tune.../index11.shtml
