Storing Advice: Windows up or down in detached unheated garage?
This question occurred to me today, as I went to retrieve something from my '71 Coupe.
I park it in a detached, unheated, non-climate-controlled (barely) one-car garage.
Today it was warm, and due to the torrents of rain, humid.
I keep the car on a battery-tender through the winter, and roll the window down a little to run the battery-tender through the opening.
The cold vehicle developed condensation from the (relatively-warm; ~50ºF) humid air, both on the exterior of the car and on the interior of the t-tops.
I will be using a car-cover (just arrived) once I've got the car cleaned off in the next dry/warm spell, but I'm wondering whether I should store the car with the windows up except for the one I have open a crack to pass-through the battery-tender cable, or whether I should keep both windows rolled-down, so that any humidity that condenses would also dry off asap from the air-circulation.
Turning my garage into a sealed or climate-controlled garage is NOT an option at this point.
I would appreciate any insight or experience anybody has on this kind of situation.
Do not use a car cover if your garage floor is sweating when the temperture changes from cold to hot quickley the car cover will only trap the moisture under your car every thing thats not painted will have rust on it in six months. When your garage floor was poured they probably did not put a vapor bairer under the floor, I had this same problem about 35 years ago the problem will go away when the ground quits freezing then you can use your car cover then. When my floor got sweaty I would open the door so it would dry out.
I would recommend you don't seal the interior unless you also put a dehumidifier in there. You can't avoid the fact that the air inside will contain moisture and winding up the windows means the moisture can never escape.
As you probably know, all air carries moisture to a greater or lesser extent. When the temperature of a surface, or the temperature of the air itself, falls below the dew point the moisture will condense and become visible (as dew, rain or condensation). As soon as the temperature starts to rise the moisture will evaporate again. Evaporation is helped by airflow, which is why sealing the interior of the car from draughts will cause damp to remain where it sits until the temperature rises significantly.
Definitely leave the windows cracked so moisture does not build up inside the car.
If the purpose of having a car cover on it is for just keeping the dust off, go to Walmart and buy a couple sheets and throw them over the car. The sheets will be soft and loose and will not allow moisture to be trapped. When spring comes around you can just pull them off into the washer and they will be clean real easy.
Be sure to also buy a few bars of Irish Spring soap. Place the soap in a glad bag with some holes in it. Put the soap under the car to keep the critters from using your ride as a winter condo. Some folks put the soap inside the car if you like the smell of it. You can find several threads on this from others on techniques.
Rd
Rd
Rd
Rd
New one to me on the Irish Spring. Have to try that instead of the mothballs. Much better smell.
Happens to me too. The concrete is cold from the 20 degree weather we've had, add the 50-60 degree air, and you have moisture. It takes a week of 50+ degrees to bring it back up to non moisture temperatures. I've found the best thing to do is keep the garage closed on those mild winter days. It keeps the cold in, but the moisture out.
I have the same problem - in fact I was cursing last night as I went out to my garage. The floor is moist to say the least! Mine was poured in 1950 so there isn't a vapor barrier and the temperature variations produce plenty of condensation. This may sound weird, but I cover the entire floor area that the vette is parked at with cheap kitty litter. This prevents moisture from transferring up to the frame from the floor at the very least. I keep the windows cracked open around 3-4 inches as well. The kitty litter also helps in case you happen to have any leaks over the wintertime. Come spring, I back the car out and clean up with a push broom and I'm good to go!
When I went out this morning, the rain had begun to dry outside and the moisture was gone from the outside and inside of the car. The garage is quite drafty, so I don't have to open a window to get ventilation through there. I have plans for a new garage, but those are ten-year plans, so in the meantime, I'll see what I can do to minimize the temperature-changes faced by my car; maybe wrap, insulate and side the exterior, and take the car out for a drive on any days warm enough to condense...
I'll check in on the car-cover which doesn't "cling" to the surfaces, and see if it's breathing enough or trapping moisture. It is the Tri-guard Coverking cover that Southern Car Parts advertised; fits nice but not skin-tight, and seems like it would breathe well.
remember that mice can get in a crevice as small as a pencil, they will find a way inside no matter what you do... a couple of mouse traps and irish spring soap are probably pretty good ideas on a detached garage setup..
I suppose I could avert a lot of this problem if I could route the charging-cable for the battery-tender out through the battery-box rather than the door. Has anyone done that before? I'm guessing a small grommet would allow me to run the cord out the bottom. There's no pre-existing body-plugs in that area that I could run it through, I'm guessing? I've already checked, an the existing holes for the vent-tubes are too small for the cable to pass through. I suppose I could enlarge one of those holes and run the vent-tube through the same grommet as the charging-cable. Then I could have the Irish Spring and the dessicant sealed up in the car through the winter
Given the way you are storing your car, you could end up with serious problems regardless of what you do in the garage. I recommend storing the car in a bag ("The Bag") to isolate it from any moisture.
wow lots of advice......so heres my two cents.....use the green mouse bait blocks in every corner of the garage and along the walls and under the car , leave the windows open about an inch to an inch and a half, leave your battery tender cord running out like you do now, those gray tri pleat covers breathe very well, i have never found mine to absorp or trap any moisture under it
I have my 69 stored in a attached garage with a trickle of heat coming from vents in the ceiling. We have a room over the garage called a game room. I don't have a moisture problem but to be on the safe side, have a large plastic sheet covered with an old carpet under the car. The plastic acts as a vapor barrier. Hope I'm doing the right thing. Love the idea of Irish Spring. Will place that down as well. Call it preventive maintenance.
John
John
I've never used these or know anyone who has, but a lot of people use Griot's products.
http://www.griotsgarage.com/product/...rrivals&page=1
I've heard that you can also keep the little bags from inside packaged electronics and use them as well. They also recharge in the oven. The only way I know of keeping moisture off of electrical connections in areas that aren't well ventilated (ie the dash).
