Willcox Wiper Motor Testing Video done! 68 and 69-72
Old 02-28-2010, 11:09 AM
0Willcox Corvette
Former Vendor
Willcox Corvette's Avatar
Received 1,813 Likes on 1,458 Posts
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
Thank you Chris.
I'm not sure I know how to save it... but we should have this on the site in the next round of upgrades..
Were tinkering with it right now. If not, I may be able to email out the file.. I've not looked to see how large it is. Let me check on this.
Willcox..
Old 03-02-2010, 10:24 AM
0Willcox Corvette
Former Vendor
Ok, I may take this a step further. I've got one of the guys in the shop working at putting kill switches in frankenmeter (our test machine).
This will allow me to to kill power on individual wires and do some more testing. When a motor is hooked up to our tester it is wired just the same as if it were in a car complete with relay, and a stock switch. I'll get it done and see if this brings new light to the table on diagnostics... then maybe record some new vids.
The videos above illustrate how to test the motor off the car and what happens when the correct power and grounds are applied. You can verify the motors before you install them or test yours to see if the problem is the motor or the car.
Testing with the machine and being able to knock things like the grounds, and maybe the relay may be a way to diagnosis the problem on the car without removal. When they get this done, I'll take a look and see if it's worth doing.
Willcox Inc.
Old 05-19-2010, 09:51 PM
0Willcox Corvette
Former Vendor
bumping this..so I can find it..
Old 06-18-2010, 06:20 PM
john roth
john roth's Avatar
Default Electrically Challenged
I have watched the very cool you tube vid on here a dozen times. My motor is not parking but runs on clicking with the by pass on and then smoothing out with the switch on. By pass off and nothing. I'm here cause I'm frustrated. We (Wilcox, you & me) had this working last winter. I only wanted to get the motor to park so I could install and adjust the arms. That was a week ago. I have tried it all, nothing seems to be wrong, power were there is supposed to be power, ground were there is supposed to be ground. New wiring harness, motor and switches.
Any body have any ideas ?
JR
Old 07-15-2010, 10:48 PM
0Willcox Corvette
Former Vendor
John...
Missed this post... sorry..
go to the 1969-1972 video.. and at or around the 2.17 mark.. see if this is what your motor is doing..
If.. with the switch off.. the motor runs and clicks like in the video then you have a ground issue... it is illustrated at the very end of the video..
Willcox
Old 08-28-2010, 08:06 PM
0Willcox Corvette
Former Vendor
bump.. Someone is looking for this tread.
Old 11-07-2010, 07:14 PM
fazang
fazang's Avatar
Free Bump
I just successfully used the vid and PDF and tested the motor...
It works !!! so now onto REALLY why the wipers are not working
-ALF out....
Old 11-07-2010, 08:00 PM
flaco1801
flaco1801's Avatar
that sounded like norm... yes? no?
Old 11-12-2010, 02:01 PM
0Willcox Corvette
Former Vendor
Nope.. wasn't Norm...
Old 11-12-2010, 03:33 PM
69MA
69MA's Avatar
Thanks! my motor just started doing that clicking thing and i was really scratching my head, now i know what to look for. Thanks again.
Old 11-13-2010, 02:50 PM
0Willcox Corvette
Former Vendor
good deal.. if you don't find it.. post again!
Old 11-16-2010, 07:05 PM
0Willcox Corvette
Former Vendor
bump
Old 12-28-2010, 08:36 AM
  #33
0Willcox Corvette
Former Vendor
bump
Old 12-28-2010, 08:57 AM
  #34
V4motorsports
V4motorsports's Avatar
Great videos!!!!
Fairly new to the site and am very impressed with everything Wilcox has to offer. I know where all my parts will come from.
Thanks again
Russ
Old 12-30-2010, 10:10 AM
  #35
0Willcox Corvette
Former Vendor
Thank you V4
Old 02-10-2011, 09:14 PM
  #36
0Willcox Corvette
Former Vendor
bump
Old 02-11-2011, 03:33 AM
  #37
Chromie69
Chromie69's Avatar
Originally Posted by Willcox Corvette
bump
Awesome you bumped this..my car does the high and low speeds but will not park..I unplugged it last summer and put rain x on the windshield..I put it on the low side of the list..they worked sort of when I got the car but were difficult to get to park..I will listen to it to see if it is just clicking or wanting to park but don't remember hearing that noise..the **** under the steering wheel does shut it off but it wont go low enough to use it that way..Any words on washer pumps for windshield and headlights? When you push in the switch to make it pump it makes a noise for about 8 seconds then stops..maybe the pump piston going..but nothing comes.out? Any how I think it may need some new gaskets in there ..sounds like you got a new customer as I am sure this thing needs some part or another to fix it..
Thanks for the info.
To Willcox Wiper Motor Testing Video done! 68 and 69-72
Old 02-12-2011, 12:44 PM
  #38
0Willcox Corvette
Former Vendor
Had someone one looking for how to test the motors, this has always been the easiest way to let them know. There is more information on your wiper system at this link.
Corvette Windshield Wiper Motor Wire Schematic 69-72 with test
http://willcoxcorvette.com/repairand...elp.php?hID=95
The washer pump for the windshield and for the headlamp washers are activated by the same wires, the blue and the yellow that also run to the wiper motor three wire connector.
The windshield washer pump works off a diaphragm pump but the headlamp washer is controlled by a solenoid and pump.
Willcox
Old 02-12-2011, 12:48 PM
  #39
Chromie69
Chromie69's Avatar
Thanks so much..will check out the wiring diagram..
Old 02-12-2011, 01:54 PM
  #40
427SIXPACK
Support Corvetteforum!
427SIXPACK's Avatar
Mine doesnt squirt ( Oh i can hear the comments now ) hopefully this video has info on this topic as well...........( REAL ANSWERS )
Thanks for taking the time to make & video & sharing !!!
Quick Reply: Willcox Wiper Motor Testing Video done! 68 and 69-72
