Torq Thrust II - Pics to Share on Car?
#141
and here...
#142
Hello,
I search the good TTII for my new 69 coupé with no modification.
I would like a combo 17" front and 18" on the rear
i supose 17x8 4" back space on the front
but i don't find the info for the rear .
Thanks a lot
Thanks a lot
#143
17x8 rear with 255/50R17 Nitto Invo tires
16x8 front with 245/50R16 Falken tires
I personally think the torque thrust or Minilite style wheels look the best on C3s.
I am not a fan of big flashy aftermarket wheels, I would have stayed with stock 15in alloys, but there is no street tire that grips well in that size.
Dave
SHIFT A (12-11-2017)
#144
I used a 18x9.5 rim with a 4 3/4 back space no mods to my car at all.
#145
#146
mysticpete (09-22-2020)
#150
Dementer sole survivor
Received 6,289 Likes
2016 C3 of Year Finalist
#151
As I understand stock wheel sizes for the generic C3 Corvette:
15' wheel, 8"rim, with 4" backspace.
Somebody correct me if I'm wrong.
From reading this thread it seems that wheels with backspacing range from 4" to 4.5" will work fine....I'm assuming an 8" rim and 17" or 18" wheels.
Also, it seems that there are very few aftermarket wheels that are available with the 4" backspacing. Is that about correct?
#152
i think theres actually quite a few. You either need to contact the manufacturer or look at the vendors sites. I had a catalog from a c3 vendor that had a big selection
#153
The wheels have 4inch backspacing (-11mm offset) on both front and rear. Thats the stock/OEM backspacing
#VN5156861 front 16x8
#VN5157861 rear 17x8
Looks like I need to make a couple changes to get more traction. I am going to put 18x9.5-10 inch wheels on the back with some sticky 295/45 tires, and then move the 17x8s to the front. I wish I could get a quick launch from a stop, but I have to ease it up to speed to avoid spinning in place. I have 400 RWHP to plant, with weight reductions getting the car under 3k pounds. Ill post some pictures when im done.
#154
Thank-you for the complement, and sorry for the late response.
Dave
#155
You can find tire weights pretty easily on most tire manufacturer sites, and they seem to be pretty accurate in my experiences; but not a lot of wheel manufacturers provide weights, and they are sometimes inaccurate. For those that are concerned about adding/reducing weight with a tire/wheel combo, I have a few acurate weights to share that I have gathered all through my personal scale (all weights are with caps included);
American Racing Torq Thrust II VN515 polished (fairly light alloy wheels and decent price)
16x7, 0 offset (4 inch Backspace) part #VN5156761 $120= 16 lbs
16x8, -11mm offset (4 inch Backspace) #VN5156861 $122= 16.5 lbs
17x8, -11mm offset (4 inch Backspace) #VN5157861 $156= 18.5 lbs
18x9, 0 offset (5 inch Backspace) part #VN5158961 $180= 20.8 lbs
Ridler 695 alloy, gloss medium gray with machined (polished looking lip)
17x8, 0 offset (4.5 inch Backspace) part #695-7861G $124= 20.0 lbs
18x9.5, +6mm offset (5.5 inch Backspace) #695-8961G $133= 23.8 lbs
And if you want the stock wheel weight to compare;
15x8 OEM rally wheel= 25 lbs
15x8 OEM alloy wheel= 19.2 lbs
#156
In that picture I had
245/50r16 on the front (25.6 inch tall)
255/50r17 on the rear (27.0 inch tall)
I just barely put 295/45 on 18x9, and switched the rears to the front (I wanted more traction, ground clearance and fill the wheel wells more).
I still need to do some suspension height adjustments, and take better pictures, but here are these for now with the 295/45r18 on rear, and 255/50r17 in front;
#157
