removing paint or dye from interior plastic panels
What is the best way to remove old paint or dye from plastic interior panels without scratching them up.Some of the coating came off. I noticed the original dark saddle under it dosent match what the previous owner sprayed it with.Its more of a redish brown.
Received 6,944 Likes
2015 C2 of Year Finalist
I heard of people using "easy off oven cleaner" I never used it so I am not sure how it works on plastic.
Paints sit on the surface of materials and lacquer thinner is a good choice to remove them. Use either a pad of cloth, or paper towels; do not soak the parts in a bath of thinner. Dyes actually penetrate the substrate and need not be removed before recoloring... simply clean well to make certain all dirt and "Armor-All" type goo is gone, then spray away. Paints belong on the outside of your car, interiors should only be dyed.
What's used on interiors is elastomeric PAINT. Plain and simple Why people insist on calling it dye is beyond me. I call only imagine it's to think it's a better product than a paint, and to that end I agree. Just call it what it is. Elastomeric paint. In fact, call it elastomeric coloring that's what Dupont called their products originally used to color GM's interior pieces. I now call it a "coloring" instead of paint,(as I was rightly suggested to do), so as not to confuse anyone who may think a simple paint will work. It will not. So I took the "paint" description out of the equation, how about getting rid of the dye.
BTW.....I do agree with the lacquer thinner removal suggestions
surfrocker1 (01-17-2020)
A semantic exercise Dennis. The elastomer in your "colorant" is the vinyl carrier. The actual color may be a ground up solid "pigment", or a liquid "dye". Which may or may not penetrate the surface of whatever material it is applied to... dependent on the porosity of the substrate.
