Bench Test Wiper Motor
I have a wiper motor for a 67 Chevelle, it has 2 terminals away from a single terminal (3 total) for the motor and the pump has 2 side by side terminals. How would I bench test this, every thing I have tried hasn't worked, what is hot, what is ground, WHAT WHAT WHAT!!!!! Thanks......................Bruce
The way it usually works is the case is ground. One of the 3 terminals will be 12 v, the other 2 terminals are grounded for the 2 different speeds,ground 1 and it runs on high,ground both and it runs on low.
